PIP Charging Cable
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Johnny C, Jan 4, 2013.
  1. Yes, hook or something similiar
    26 vote(s)
    65.0%
  2. No, just hang from outlet.
    14 vote(s)
    35.0%
  1. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
  2. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    mmmodem likes this.
  3. Johnny C
    Johnny C Member
    162
    Boston
  4. ukr2
    ukr2 Senior Member
    1,010
    276
    31
    Victor, NY
    Yeah, and it's just a 3-wire plug.
    The Amazon price is half.
    The Righ-Angle won't pull itself out of the outlet with the weight of the brick pulling straight down.
    DadofHedgehog likes this.
  5. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
  6. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
  7. Big Dude
    Big Dude Member
    207
    76
    Wisconsin
    I have a regular outlet in the garage rafters for my garage outlet. I plug the PIP charger cord into an empty receptacle and zip tie the cord along the rafters, supporting the brick and cord. I then have a simple bicycle hook screwed into the rafter above the place where my pip parks and hang the charger plug on that. Works great. Supported and stays out of the way.
  8. Johnny C
    Johnny C Member
    162
    Boston
    Got my hook installed
    DadofHedgehog and lensovet like this.
  9. priuskitty
    priuskitty PIP FAN
    2,286
    335
    Clawson, Michigan
    2015 Prius Plug-in
    now that we had 60 degrees today, my charging cable is soft n supple, not stiff, like when it was 23 degrees out:cool:
  10. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Thanks, I'm ordering one now. It is currently $5.93 as I type this. I don't need the angle as I lay my brick on a box. I just dislike unplugging and plugging in the EVSE twice everyday at work and at home. I feel like I am putting extra wear and tear on the plug. The walkie stacker pallet machine at our warehouse require a particular position for the plug in order to charge. I don't want to have that happen to a $1000 EVSE or whatever Toyota charges for it.
  11. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I originally used a bungee cord, but since I moved my EVSE into the attic of my garage, I mounted a wire basket onto the rafters, and have it resting in that. Can't find it online, but it looks very similar to this. It's just the right length/spacing, allowing the entire unit to rest, with no strain anywhere.
  12. Johnny C
    Johnny C Member
    162
    Boston
    I like the the basket idea. [​IMG]
  13. Like a piece of coat hanger. plenty strong, handy, cheap plentiful and flexible.
  14. REmmons
    REmmons New Member
    Richmond, VA
    Just out of curiosity, that looks like a parking lot light pole you have the wires coming out of. We have similar light poles where I work, but I was told the power at those poles doesn't come on until after dark, so even if we tapped into the power in the pole, it wouldn't be active until it got dark outside. Did you have similar issues or is the power always on on those light poles?
  15. Electric Charge
    545
    133
    Syracuse, NY
    I have the same issue with timed light poles at work. I thought for sure that they would be running 120V to the lamp post, and use a relay in the lamp post itself, but they told me that all lamp posts high voltage wiresare homerun, and controlled from within the building.
  16. bisco
    51,851
    10 degrees at work tonite, first time i've noticed any stiffness.
  17. DLee
    DLee Junior Member
    81
    At least it is outside, away from structures. Is that a flammable pole?
  18. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    Here's a easy 15 minute solution for a garage. Used the support brackets for the garage door opener to run the charger cord above the PIP using zip ties. Simple plug in on both ends without the cord hassle.
  19. Electric Charge
    545
    133
    Syracuse, NY
    IMO you have too much tension on your cable. Also check out the link in my sig ;)
    -1- likes this.
  20. bisco
    51,851
    i have the exact same setup! fortunately, i'm not tall enough to hit my head on it.:p
    -1- likes this.
