Creases in 2012 PRIUS Three Leather Seats
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rogerteel40, Jan 8, 2013.
  1. rogerteel40
    rogerteel40 Junior Member
    Pensacola Florida
    Has anyone seen or had creases in the new leather seats. I reported this to the dealership. This is from the drivers seats and I have several in the rear seat. The car is 2 months old.
    52,198
    i don't have leather, but i like the look of creased leather seats. altho, yours look a bit more wrinkled than creased.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The leather on my 2010 (w/ 38K miles) has no creases, so I'd say that's not normal--especially for such a new car.
  4. jayrider
    jayrider Member
    163
    17
    southwest illinois
    The Prius Three comes with cloth seats. You need a Four or Five to get leather. If you have a Three and have leather then it was dealer installed. May be wrong but feel pretty strong on this opinion.
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    That doesn't look right. If you have a Three with leather then I would find out which brand you have because it shouldn't be Toyota Softex. It is likely a Katzkin kit. Either way that doesn't look normal to me but I only have cheap Clazzio covers to compare.
  6. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I agree. I don't know who installed your "leather" (doesn't look like leather to me) but I don't think they did a good job.
  7. frodoz737
    frodoz737 Top Wrench
    4,711
    2,513
    33
    I used my Dealers local vendor to install the perforated leather prior to delivery and came with a 3 year warranty. They used the same kit as regional. Later had it replaced with "solid" as I had similar problems, and worse. If yours was installed at regional or through the local hack-shack, the dealer should take care of you. By the way, the solid non-perforated leather is much more resistant to wear and spills, and subjectively speaking, I think it looks much better. Picture below shows fibers pulling through the perforated lather from vacuum after just 3 months. Was replaced shortly after this.
  8. Miata Racer
    Miata Racer Junior Member
    58
    St. Louis, MO
    That sure looks like the standard "cloth" in a 2012 Prius?? It's fairly smooth in texture so could - maybe - be confused for leather...
    But a note on Katzkin and most other aftermarket leather interiors: they are normally BETTER quality than factory leather. At work we have a 2001 Mazda MPV van that the dealer added leather to when new, and all these years and 100k miles later, and not garaged the past few years, and the leather is pretty much like new still. I bet it's never been conditioned, either, which is something I do religiously with my personal vehicles.
