Intelligent Tester
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Porsche998, Nov 10, 2008.
  1. Porsche998
    Porsche998 New Member
    Massachusetts
    Reading the workshop manual and posts here on this forum, it appears that one needs the Toyota Intelligent tester for some of the typical maintenance operations - bleeding the brakes for one. My Toyota dealer states that they do not seel the tester. Is the tester avaiiable elsewhere? I have a 2008 model. Thanks for any info.
  2. hobbit
    hobbit Senior Member
    4,089
    469
    Bahstahn
    Yes, but a [possibly used] Mastertech 5100 with a Toyota manufacturer-
    specific cartridge or even a recent version of Autoenginuity
    can probably suffice for a lot less coin. As dealers upgrade to
    Techstream, I'm kinda wondering what happens to their old Mastertech
    tools ... although they're probably still useful for other cars too.
    It is possible to bleed *most* of the brake system without a tool by
    various combinations of power on, power off, relays pulled or not,
    etc but I'm not sure anyone's researched and written up a good
    procedure for it. A solid understanding of how the system works
    is an essential starting point, and much of that can be found at
    Autoshop 101.
    _H*
  3. galaxee
    galaxee mostly benevolent
    9,810
    469
    MD
    h, most dealers are keeping the scantools for now. they're buying the minimal number of techstreams possible and using the scantool where it still applies. DH had hope of buying one back in the day when techstream first came out, but they wouldn't even sell to him.
  4. hyo silver
    hyo silver Awaaaaay
    15,269
    1,604
    off into the sunset
    2025 Prius Plug-in
    XSE Premium
    An eight thousand dollar tool to bleed the brakes? Wow. I remember doing this in the driveway with a glass jar and a helper to pump the brake pedal. :)
  5. prius213
    prius213 New Member
    Following up here to see if anyone has bought an Intelligent Tester to-date, as the last post here was a few years back. Interested to get one, but not for $8k.
  6. CaiYanzhang
    CaiYanzhang Junior Member
    Carlifornia
    2011 Prius Alpha
    Tis Techstream is cheap and work good, but it limits the data recording to sets based upon controller so doing an engine, transmission, and battery study is all but impossible. But IT2 is able to do all. You can still found some cheap around $300 on the aftermarket
