Add guidelines to the backup camera display
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Rich London, Jan 13, 2013.
  1. Rich London
    Rich London New Member
    Charlotte, NC
    I have a 2008 and 2009 Prius. Is there a way to add guidelines to the backup camera display?
  2. Britprius
    Britprius Senior Member
    5,194
    1,921
    Herefordshire England
    Hello Rich, you can add guide lines to the display if it is an OEM setup you have on a Prius.
    If I remember correctly you turn the auto backup system on and there are touch buttons on the display to add the lines.
    The display I find most useful is with two strait green bars that show the position of the car in a strait line, and yellow bars that curve as you turn the steering showing the path the car will take for a given steering angle.
    If this does not work let me know as I am going out for a short while later and will double check.
    John (Britprius)
  3. Rich London
    Charlotte, NC
    Both cameras are original equipment from Toyota. I reread the manual and can't find any screen settings to turn guidelines on. I don't know if the lines were part of the 2008 and 2009 cameras. If not I would be interested in an aftermarket add on. I look forward to additional input.
  4. Britprius
    5,194
    1,921
    Ok am going out shortly and will be back in 90 mins with full update.
  5. prius4eva
    prius4eva New Member
    hi try navtool they are @ navtool.com thy may have a solution, i have purchased my back-up camera kit from them
  6. pjc
    pjc Member
    139
    46
    Bloomington, MN
    For some reason, I have the feeling they don't put the guidelines on cars in the US. For my life, I can't figure out why. Do they think people here never back up into a parking space ever? I had never seen any car with the guidelines until I went abroad...
  7. Britprius
    5,194
    1,921
    Rich, update to backup camera. If you go into reverse with auto park turned on "so reverse picture comes on" then turn auto reverse off.
    On bottom left of MFD is a button, touch to scroll through 3 different modes.
    Hope this helps.
    PS, no offence meant but every time I respond to one of your posts I keep responding as if you are in the UK because of your avatar. Guess I'll get use to it soon.
    John (Britprius)
    DigitalDervish likes this.
  8. ncprius07
    ncprius07 New Member
    Winston-Salem, North Carolina
    Just acquired a 2007 with factory backup cam and nav. I don’t think the auto park was ever offered in the US market. I guess we’re that good at parking, NOT!
    I still would like to have the guidelines on the screen. Is this even possible with a US spec car?
  9. pjc
    pjc Member
    139
    46
    Bloomington, MN
    Sure, just go get a Sharpie... :D
    NortTexSalv04Prius likes this.
  10. LlF
    LlF Junior Member
    42
    Canada QC
    When I park my car, i like to align the guidelines with the yellow parking marks on the ground, so I know my car is right in the center of my space. (OCD sorry)
    as you can see from the attached manual extract, even-thought the car is perpendicular to the line of poles, the camera shows them curving, because the camera isn't mounted dead center.
    So it's very frustrating when you try to adjust your position with the camera only to realize you were off because the camera was off center. /rant
  11. ncprius07
    Not even remotely helpful or funny. This why I rarely post.
  12. bisco
    52,081
    my wife's new hycam came with the guidelines on the 6" screen, not sure if prius is getting them.
  13. EvilTwinTLR
    EvilTwinTLR New Member
    Salt Lake City, Utah
    My Prius is a pkg II with the standard MFD, can I adapt a backup camera into mine?
  14. NinnJinn
    NinnJinn Member
    276
    Indiana
    If your 2008 is actually a package 2 or higher, you should already have a backup camera.
  15. EvilTwinTLR
    It's not. It's just a pkg 1. No camera. Is the head unit the same in the I v. II? I thought it was a Pkg II. I was wrongo.
