vibration or more of a shutter on deceleration
Discussion in 'Prius c Main Forum' started by WX4GPS, Jan 15, 2013.
  1. WX4GPS
    WX4GPS Junior Member
    64
    TMMK Georgetown KY
    I have noticed, and this seems new and not a change in my driving habits, but when driving the prius c, and I am on rolling country roads, I like to loose speed as I go up hills if no cars are behind me, but here is the problem that has become noticeable.
    If I am driving 50 or 55 and I keep the gas applied lightly where the meter is just above the eco mid line so the engine is on at these speeds, but I am slowly loosing speed as I go through the low 50 and most of the 40 MPH speeds there is a very noticeable shutter and you can feel it in the steering but its also throughout the car that you can feel it but it will slowly go away as you get down into the 30's, if you completely let off the gas it does go away and if you do a moderate acceleration to start gaining speed it goes away.
    Its almost as if the device that engages the motor into the drive train is not designed to be loosing speed when engaged... has anyone else noticed this. Is it something I should have Toyota look at?
  2. vernon birdman
    vernon birdman Active Member
    330
    141
    Vernon BC Canada
    I haven't experienced this on mine
  3. poser
    poser Junior Member
    Alberta
    i find that too, I think its just the ICE not revving enough and kinda struggling/not making enough power. Its like a car in the wrong gear and engine is bogging down. When I get that, I just give it a little more gas and away she goes.
    It doesn't worry me.
    Rob.au likes this.
  4. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    I'm also aware of it. Most of the time the ICE is running at a higher, efficient load and those times where it isn't just don't feel quite right.
  5. TrafficMPG
    TrafficMPG Junior Member
    I've noticed it as well. Right around that ICE cut off mph.
    mertechperformance likes this.
  6. BrunoPuntzJones
    107
    28
    Same
  7. StockLX
    StockLX Junior Member
    Halifax, NS
    Hi Guys. Any of you in Canada (or other cold places) notice this is worse in the winter vs the summer months?
  8. evil03
    evil03 Junior Member
    Does Anyone fell this similar feeling on low speed acceleration or deceleration? Around 16mph to 20mp?
    I just started to notice this
  9. vernon birdman
    330
    141
    Vernon BC Canada
    After just over 2 years in moderate to high heat (up to 108 f in the California high desert last fall) and as low as -15C last winter, I have yet to experience this phenomenon.
  10. mahout
    mahout Active Member
    655
    116
    NC
    When using the brakes lightly you may be expeiencing the pulsations from the brake rotor(s); check ypour pads to see if they are pretty equally worn and the rotors forwarped condition or spots of brake pad material 'glued' to the rotor. Usually thats a sign of brakes being 'on' and stppee for a length of time.
  11. vikisonline
    vikisonline Junior Member
    ontario
    Just got a 2013 prius c. Ops description is exactly what I am experiencing. Same speeds too.
    Easier to reproduce on a very slight down grade.
    I know its an old thread, but its the only of its kind I could find.
    Any of you had long term problems resulting from this?
    Did you just decide to live with it and things are still fine?
    Thanks!
  12. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    If your talking about the "shudder" as if it can't decide whether or not to shut off the engine an go full electric right around that "line" on the ECO screen - yeah I know that shudder. I've not read any other threads where people have had any issues however. I'm guessing most are like me and either apply more gas pedal, or let off enough to go full electric to get that shudder to go away.
    I do admit to worrying about it at times...
  13. vikisonline
    ontario
    Yep, right around the end of the eco line. sometimes under, sometimes past. If under usually its at higher speeds where it cant go into golfcart mode. Highway too if im losing speed at a specific rate. And sometimes, sometimes at a certain speed on the perfect down grade the cruise can do it too. Thats more annoying. I guess I could compare it to shifting a manual into too high of a gear where now the engine is forced to run below idle rpm.
  14. dubit
    dubit Senior Member
    850
    538
    Indiana
    2016 Prius c
    I hate to say this, but I've been told it's "normal" operation. Used to work at the dealership where I bought the car for many years. Have went to lunch with a couple of my friends there (Tech & sales guy) and pointed this out to them. Both said it was normal, and to do exactly what I have been doing - either apply/let up on the pedal.
    Still hate that it does this though & as I said earlier I do worry about it at times. I don't try to let it just continue shuddering in fear that it will do something. So I apply/let off the gas pedal, but darn that's a pain as well, because I don't need to go faster, or slower.
  15. vikisonline
    ontario
    Well its good and bad. Saves me a drive to the stealers. Thanks :D
    dubit likes this.
