POOR MPG IN THE RAIN
Discussion in 'Prius c Fuel Economy' started by KMAN4190, Jan 15, 2013.
  1. KMAN4190
    KMAN4190 Junior Member
    57
    I noticed on 2 or 3 occasions driving around the same speed coming home from work that the gas mileage really drops in the rain. I assume it has something to do with resistance. Anybody else notice thís?
  2. F8L
    19,011
    4,083
    Grass Valley, CA.
    It takes a lot of energy to pump water off the road and spray it into the air. :)
    Yes, it happens to every vehicle.
    KK6PD and JimboPalmer like this.
  3. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    F8L likes this.
  4. Boatycall
    Boatycall Junior Member
    37
    Tacoma, WA
    Try owning one here in Seattle.... Yes, rain definitely makes a difference.
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    At 8.34 lbs per gallon, it's gonna slow you down. Just be thankful it does not rain tapioca pudding.... :)
    cknfts likes this.
  6. koipond
    koipond Member
    198
    40
    noticed the same thing. Interesting how being aware of your MPG makes you so aware of all of the variables that affect it, which many of us never considered in our past driving lives...
    Yves Grenier likes this.
  7. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    Same here. It actually hasn't rained that much since I got my C, but the few times it did I noticed a marked decrease in my MPGs. Thank goodness I live in the desert!
  8. Gcoop
    Gcoop Member
    156
    79
    niagara region ontario canada
    try sleet and snow.. lol
    i was avg 4.8l/100 on a tank (49mpg) in nice weather
    now im avg about 5.7l/100 per tank(41.27)in winter
  9. robsnyder20
    robsnyder20 Active Member
    378
    302
    SW Florida USA
    In my toyota matrix I averaged 8 less MPG in my 36.5 mile commute than normal, decent rain all the way home yesterday. Wind makes a big difference also I noticed when hypermiling
  10. TC400
    TC400 Active Member
    751
    169
    Pittsburgh, PA
    Try winter driving >.<
  11. Blu-ray
    Blu-ray Blizzard Brigade #215
    471
    198
    TampaBay, FL
    It rained pretty hard on my commute home on Wednesday. It took me 2 hours to get home which is only 16 miles away and normally takes 45 minutes to an hour. I noticed the mileage tanked from my standard 60's to 49. Here in Central West Florida we have nasty thunder boomer down pours in the Spring and Summer. I use to love driving in the rain, now I'm not too sure. However, Princess Pea held her own in the rain much better than what I thought she would. I was rather surprised because of the LRR tires and less grip than what I'm use to. But it did well. But then again, the tires have less than 2K miles on them. LOL
    But yeah, mileage can tank in ran storms.
    coyote303 likes this.
  12. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Try to drive with the hurricane, not against it. It isn't just the liquid water. The humidity also has an impact. In a Prius you'll notice EVERYTHING affects the fuel economy.
  13. iSphinx
    iSphinx Junior Member
    31
    I know this is probably not what this particular thread is about, but this was the first post I see that mentioned about rain. For this car, whats the "safe" amount of water level can this car drive through before doing any harmful/expensive damage? I'm assuming a small puddle would be fine, but I would like to know the limit this car able to handle. Houston is known for the their floods every now and then when it starts raining so I just want to be prepared.
    RocMills likes this.
  14. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    Expensive damage would depend on the persons income... but for me, it would be water above the door plates. Once it gets into the car you pretty much have to replace the carpet... next on the rise is above the exhaust manifold as you are now flooding the engine. (Please note: submerging the exhaust pipe will not allow exhaust gases to escape creating a back pressure situation that can hurt the motor as well. Just because the engine is out of the water doesn't mean you are safe.)
    iSphinx likes this.
  15. iSphinx
    31
    Yes that was what I meant by "harmful/expensive" damages lol BUT, my insurance should cover that. Overall, I will keep in mind any water level thats even near my door plates I will be extremely cautious. Thanks for the tip!
    RocMills and ztanos like this.
  16. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Insurance companies will try to fight flood damage. If they can prove in any way that you drove the car into the water knowing it was deep, they won't cover it. So you should always go with the safe approach. If you can't see how deep it is, go around.
    iSphinx likes this.
  17. Rain isn't really a big deal. My mpg was *barely* affected by rain when I did a few hours of highway or fast-backroad travel in the rain a few weeks back (and with my lights on):
    57 mpg in the rain and 61 mpg on the backroads
    - I basically get these same numbers when it isn't raining.
    Rain isn't such a big deal to me as wind or winter travel.
    iSphinx likes this.
  18. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Yeah, mine takes a hit of about 3 mpgs.
    minkus likes this.
  19. minkus
    minkus Active Member
    369
    125
    Cleveland, OH
    My drop is a bit higher - 5-10% of the mpgs I'd get otherwise. ~70 mpg to/from work when it's dry, ~65 mpg when it's wet. Flinging more water around means I can't glide as far.
  20. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    5% of 70 is 3.5mpgs :)
