3rd Gen Hybrid eCVT Transaxle in the Classroom
Discussion in 'Gen 3 Prius Technical Discussion' started by cycledrum, Jan 25, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Get a good look at the 3rd Gen MG1, MG2, clutch plate and power split gears on the bench and explained by an automotive professor. 3rd Gen Prius has motor speed reduction planetary gearset not used in 2nd gen, allowing higher speed for MG2 and 2.5 to 1 torque multiplication for more powerful electric drive and higher EV speed. This design was also used in 2006 HiHy and 2007 CamHy.
    Enjoy!
  2. pichner
    pichner Metallic Maniac #001
    66
    Minneapolis, MN
    I have watched this bad boy a few times, great info!
  3. Britprius
    Britprius Senior Member
    5,194
    1,922
    Herefordshire England
    Why has the gen3 version flywheel got a ring gear.
  4. pichner
    66
    Minneapolis, MN
    They had to make that crazy speed reduction "thing" to allow the electric motor to operate at higher wheel speeds. At least I think that is what you are asking about.
  5. Britprius
    5,194
    1,922
    No. If you look in the beginning the gen2 flywheel that has the torque limiter clutch in the middle has no ring gear obviously because the Prius does not have a normal starter motor. Then look at the gen3 flywheel and it has a normal strait cut ring gear on it (not mentioned in the demonstration).
  6. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Good question, could it be they use the same flywheel as the non-hybrid vehicles that share that engine?
  7. Sabby
    Sabby Active Member
    295
    127
    SoCal
    Thanks for sharing. Finally explains how the plug in can hit 61 mph without the gas engine on, compared with 46 mph for the Gen III without overspeed on MG 1.
  8. Britprius
    5,194
    1,922
    That was my first thought but that would also apply to the gen2 version. Toyota would not do this however. Just think cost of making and fitting ring gear (heated and shrunk on) say £10-$16 at factory prices, on 1 million cars or more since gen3 start of production = £10,000,000- $16,000,000 they do not through that sort of money away.
    John (Britprius)
  9. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    That's just great. Thirty minutes of youtube footage and I'm no longer happy with my Gen II and its antiquated technology. Toyota just had to add a second planetary gear set to the eCVT to transform my Gen II into a Model A. Sigh.
    But thanks much for the vid, cycledrum. I have the Gen II eCVT teardown/demo from the same folks in my video archives.
    Now it's time for me to find a >100K mile Gen III for under $10K. Let the search begin!
  10. El Dobro
    El Dobro A Member
    7,088
    3,270
    It could just be a flywheel that was lying around the shop and used for the demo.
  11. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Nice observation! For what it's worth, the factory repair manual has several illustration that show the Gen III flywheel in line drawing format. No teeth show in any of them. That's not conclusive because maybe they just didn't feel like drawing the teeth :D . Possibly the flywheel in the picture wasn't from a Prius?
  12. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    He mentioned that 3rd Gen transaxle was a P310 from a 2008 Highlander or Lexus RX hybrid. Sounds like 2nd Gen transaxle was only used in Prius.
    Sorry if this video spurs one to sell off their 2nd gen :eek:
    xs650 likes this.
  13. jadziasman
    1,355
    488
    District 6
    I was just being sarcastic, which is difficult for me to express with text and I'm not sure which emoticon works for that.
    I always wondered how the Gen III Prius could achieve better mpg than the Gen II with a larger ICE. Now I know.
  14. telmo744
    telmo744 HSD fanatic
    2,181
    769
    Portugal
    Larger ICE usuallty lowers BSFC, and Toyota confirmed that when launched GenIII. Transaxle improvements are also to be taken in account but may not be as determinant.
  15. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    not sure if this is my pc or something but the sound is awfull for me many places can not understand the words from the noise ... is this just me ???
    other youtube stuff works though
  16. tumbleweed
    4,067
    692
    Eastern Oregon
    I just tried it again and it looks and sounds OK on my computer. I think it uses Adobe Flash Player, try downloading the latest version.
    YouTube videos won't play? - YouTube Help
  17. szgabor
    994
    175
    Oceanside NY
    Thanks ..
    What solved the problem for me, is to download the video completely and then watch it ... that way it was fine. Not sure why I had problem with streaming.
    And it worth the wait... I had an idea how this works but really seeing the parts "outside" was amazing. It would be even better if the video would show where and how all these sit in the car. Like when it it taken out.
  18. Madduck
    Madduck New Member
    22
    SLC, Utah
    Does anyone else wonder what this guy looks like? Probably just like my auto shop teacher in high school.
  19. Feri
    Feri Active Member
    761
    144
    Maldon Victoria Australia
    I'm no expert but isn't this because Gen II used a chain for power transfer and Gen III uses gear to gear?
    Sorry hadn't seen the video when I wrote above.
  20. Madduck
    Madduck New Member
    22
    SLC, Utah
    This video shows a stylized location of the transaxle in the car. The video is of a Lexus but it is the same design.
