Does the ICE warm up for first run of the day
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CaliforniaBear, Jan 26, 2013.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    I'm a 2012 Prius Three owner already dreaming about a plug-in that I should probably have purchased.
    I make a short trip to the gym every morning, 5 miles round trip. Will the ICE in the plug-in stay off until its power is need up hill or the heater is turned on?
    My return trip has 0.5 miles of about 6% uphill grade. At what speed would that require the ICE?
  2. Ken Blake
    Ken Blake Active Member
    351
    180
    Portland, Oregon
    If you do everything right, the ICE will not come on. I drive 7.6 miles to work every morning and the ICE never comes on, now that I know not to turn on the heat. Not sure about speed on the grade, but the ICE comes on based on throttle position. Typically, as long as you stay out of the PWR range on the HSI, it will not come on.
  3. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Sometimes it fires up due to cold outside temps to prevent battery overcharge due to brake re-gen.
    It was 18deg here this morning- as soon as I got out of my driveway and hit 22mph - the ICE fired up for a few min then shut off for the rest of the 5 mile trip.
    Read all about it here... ICE in EV Mode ... Again | PriusChat
  4. retired4999
    2,652
    627
    Eau Claire, Wi.
    I do not know about the 6% grade, Maybe someone with a steep grade can help, if you can keep it out of power zone you will keep ICE off. If you call for heat the Heater will turn on the ICE for a short warm up cycle and will shut off, if you keep on lower heat settings and fan speed on low settings it will go a few miles on elctric then warm again. If you use no heat You can go EV for a number of miles. I just got back from getting gas, I went 8.9 miles all EV, 20 degrees out, no heat, ICE did not start for the whole trip and still had 3.1 miles of EV left. :)
  5. bisco
    51,831
    6% grade is a piece of cake. ev is more powerful than ice and 5 miles is nothing. all the best with your purchase!
    lensovet likes this.
  6. SJ PiP
    SJ PiP Member
    190
    35
    it's possible to use only ev even on a steep grade, but may not be advisable when you have an suv on your tail. however, if you need to descend a steep grade first thing in the am with a full chg, the ice WILL come on to prevent overcharging battery
  7. CaliforniaBear
    1,180
    289
    Northern California
    How does the ICE prevent overcharging the battery? Does it use gas or is it in the "B" mode, using compression without gas?
  8. bisco
    51,831
    exactly, the motor generator turns it instead of recharging. unfortunately, it must then go thru the warm up cycle.
  9. john1701a
    john1701a Prius Guru
    12,817
    5,303
    58
    Where's the hill? If it's near the end of your trip, the amount of gas consumed would be quite small. You could simply shut it off upon reaching home. The engine is heavily assisted then too. Of course, in the summer warm-up is rapid anyway.
  10. lensovet
    2,615
    496
    Burlington, NJ
    yes and no…please consult the FAQ is it covers both (a) why ICE goes on when "too much" regen happens and (b) what exactly the B mode does.
  11. CaliforniaBear
    1,180
    289
    Northern California
    Yes, its near the end of the trip. In the non-plug-in the gas used takes the mpg down around 10 mpg (usually 55 to 45) because the total trip is so short. Perhaps that would be less in the PIP where the ICE would kick in for only part of the hill or perhaps the motor would supply more of the power when the ICE is running if the battery has sufficient charge.
    You have to appreciate the folks who programmed this whole thing and the folks who find ways to work with the program parameters to get the best mileage.
  12. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,001
    Fort Lee, NJ
    My regular 2 miles trip has 5% uphill grade for 0.3 miles.
    If I get caught at the light, I have to start the climb in the middle of the hill from a stop. I can keep up with others car with about half the EV power bar. If I try to push near the end of the EV power bar, I'll accelerate faster than most cars, but not as fast as some of those "in a hurry" guys.
    If the light is green, it is a piece of cake.
