01 p3006 no lights or symptoms
Discussion in 'Generation 1 Prius Discussion' started by scotman27, Jan 27, 2013.
  1. scotman27
    scotman27 Active Member
    735
    82
    PA
    2001 Prius
    hey guys,
    last night my girlfriend and i were on our way to a party(about 16 mi away from my house) and we stopped at a light, about 8 mi from my house, engine shut off and went into ev mode. we pulled out in ev mode for a good 1/4 mile then made our turn onto the ramp for the highway, engine kicked on, my scangauge showed SOC 34.8 then it began charging as normal. next thing i know i look down at the scangauge and its showing 70 soc then 75 then 80 it went all the way to 94 then showed 0 soc. i looked at the mileage and it was showing 42 mpg something on the highway, and stepped on the gas, assist kicked in as normal, car had power. but it kept charging the battery. i scanned the car with scangauge. code p3006. checked voltage high 18.2v, voltage low 18.0v. no lights or anything. we got to the party shut the car off. turned it back on, started right up, no code, batt indicator full, scangauge said 94.6 soc. voltages HI 17.8 LO 17.6 got done the party. car starts up, no codes. 94.6 soc. car ran normal and bled off the soc back to its normal 65 something. it went int0 ev mode and ran it till the engine started again to charge the battery. everything operates normal, no codes. it was 18 degrees f out. my 12v battery is 13.6v while driving, sitting its 11.4v which i think is weak. 156k miles what do you guys think, did my car have a brain fart?
    thank you,
    scott
  2. Patrick Wong
    18,200
    6,500
    I think you should replace your 12V auxiliary battery now, to ensure that the car's ECUs have good power.
    I also think it is likely that you will face the need to replace the high voltage traction battery in the near future.
  3. scotman27
    735
    82
    PA
    2001 Prius
    thank you patrick, im going out to look at some batteries for this car. as I believe your right about the 12v battery. my traction battery i just went out and checked is sitting at 64 soc from last night and it was 11 degrees f this morning and voltages are 16.0 hi 15.3 low according to scangauge.
  4. bwilson4web
    16,187
    The 11.4V given the ambient temperatures isn't great but understandable. You might be able to make it through this winter but it sounds weak.
    The traction battery behavior sounds like a recalibration cycle. I've never experienced it but read about it. I wouldn't panic but you are watching the right metrics, min/max voltage. You might also start watching the minimum block identifier and see if it cycles or stays on one block. If it varies, no problem. If it stays on one block, you might want to be a little concerned.
  5. scotman27
    735
    82
    PA
    2001 Prius
    Hopefully I'll get some others to chime in and let know what they think. I know I can pick up 38 new 2013 cells on Ebay. I figure if the traction battery goes ill do that, get em shipped to my house and install them. so far we drove about 20 mi and nothing, steady 40 mpg and it seems fine, 30 degree weather. trunk does not smell like the battery either, im.hoping it s the 12v batt. What do you think?
  6. scotman27
    735
    82
    PA
    2001 Prius
    I got another 12v battery for it. 79 at walmart, ever ready 51R same dimensions as the optima in there. that suprises me, the optima battery is only from 2010. and its bad. they wont honor that will they? it was in the car when I got the car. (no this will not turn out to be a 12v battery thread lol)
  7. usnavystgc
    3,159
    990
    Tucson, AZ
    This has happened to me b4. It has also happened more than once. The last time was last summer and then about 2 yrs ago. I don't know what causes it but, I do know that I haven't had any problems with the car and the HV battery is hanging tough.
    I have found that with the Gen I, (especially the 01 it seems) sometimes it does some weird stuff. My protocol has been to not form any conclusions on something I see unless I see it consistently. I have also noticed that if you see something weird happening, pull over, turn the car off, wait 30-60 seconds, turn it back on and see if it goes back to normal.
    The rules I stick to on the Gen I (01) is look for consistency. If a problem presents itself, always check for flow in the inverter coolant loop. If flow exists, cycle the ignition and expect it to return to normal operation. If it doesn't then you probably really do have a problem. So far, mine has always returned to normal operation.
    scotman27 and bwilson4web like this.
  8. scotman27
    735
    82
    PA
    2001 Prius
    thank you. im starting to think that bob is right about that battery recalibration thing. i read about that. but i dont understand why it set the p3006 code but no lights. but i feel the car has better power, and higher mpg because of it. plus when i used to park at night the soc would hang around 62-64 now its at 65-68
  9. scotman27
    735
    82
    PA
    2001 Prius
    I just got done putting that ever start battery 51r from walmart. its tight but it fits. 500 cc amps
    Ever Start :sitting its 12.69 nothing connected to it, connected its 12.48. key acc 12.4. key on it says 12.0 ready mode 13.8v
    so better than the optima that was in there, i have the optima on a charger trying to see if it can bring it back.
    optima when sits nothing on it 12.1, connected its 11.9. key acc 11.8 key on 11.4. ready mode 13.5/6
    was my optima still ok or is it gone? im still thinking about one of the u1 wheelchair batteries.
  10. Patrick Wong
    18,200
    6,500
    The Optima was not OK at 12.1V, but maybe you can charge it.
  11. scotman27
    735
    82
    PA
    2001 Prius
    i got it on charge right now, i think im going to let it charge till tomorrow night after work 10pm, ill disconnect it and check it after 24 hrs.
  12. scotman27
    735
    82
    PA
    2001 Prius
    Ok update: I charged the optima out of the car for 36 hrs. Voltage last night at 10pm said.16.16. I checked it this morning, voltage was 12.97. I'm going to check it tonight at 10pm to see if it is still the same our not. If it still is about the same what do you reccomend. Return the ever start and reinstall the optima? Or keep the ever start in the car?
  13. boppo
    boppo Active Member
    799
    139
    Owego, NY
  14. usnavystgc
    3,159
    990
    Tucson, AZ
    Sounds like the Optima is fine to me. I'd return the Everstart.
  15. Patrick Wong
    18,200
    6,500
    If 16.16V is not a typo, it sounds like your charger was over-charging the battery with an excessive voltage - or your meter is inaccurate.
    One source indicates that 14.7V is the highest charging voltage that should be used.
    Charging Information For Lead Acid Batteries – Battery University
    Optima recommends maximum charging voltage of 15.6V:
    Support - Battery Care - Charging :: OPTIMA® Batteries
    I agree, if the 12.9V measurement is accurate, and holds constant after 24 hours.
  16. scotman27
    735
    82
    PA
    2001 Prius
    Yes it was a typo, it was at 15.16v last night. 12.97 this morning
  17. scotman27
    735
    82
    PA
    2001 Prius
    How many amps should my prius draw sitting with key off. And whet should my battery voltage be at with key off, acc, and on. This is the 12v side not hybrid side. I'm off work tomorrow and want to check all this.
  18. Patrick Wong
    18,200
    6,500
    Quiescent current for Classic should be ~30 mA or 0.03A.
    The key off battery voltage should be 12.6V or better.
    The READY battery voltage should be ~13.8V.
    The IG-ON battery voltage will probably be in the low 12V range.
  19. scotman27
    735
    82
    PA
    2001 Prius
    I will check that when I get home. I think my everstart went from 12.8 to 12.6 sitting. Key on was like 11.8v, its new, maybe it didnt have a good charge. I do know it's going back anyways, the Costco I work at has the 51r batteries, for $10 less than walmart and they are 600 crank amps. 525 cc amps. Wish I knew the amp hours though. Anyone know how I can figure it out
  20. scotman27
    735
    82
    PA
    2001 Prius
    UPDATE: just checked the Optima battery. holding at 12.90v since last unplugged yesterday at 10 pm. im pretty thrilled that I can get my $90 back from walmart. barring that when I put it in the car it matches up with the ever start or does better than the ever start, voltage wise. im going out to check the amp draw now while the car is sitting.
