2012 Prius Two windshield wiper issue
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Downeaster59, Jan 30, 2013.
  1. Downeaster59
    Downeaster59 Junior Member
    I bought my Prius new last July, and I am enjoying it very much. One problem has come up over the last month. I wonder if anyone else has encountered it. When the outside temp gets below twenty or so, the front wipers will not start at all when I first start the car. (No, I check for ice or snow to make sure the blades aren't frozen to the windshield.) The wipers will only work after the car has run five or ten minutes. The rear wiper works immediately, though.
    I took it in to my Toyota dealer. It was a milder day, and the wipers worked fine. The service people couldn't find anything wrong with the wipers.
    Has anyone else encountered this?
  2. tumbleweed
    tumbleweed Senior Member
    4,067
    692
    Eastern Oregon
    Welcome to PC. :)
    You haven't included your location, do you live in an area where there is a lot of moisture, rain, snow, etc? Do you park outside?
    If your mechanically inclined you might consider taking the black plastic cover (rear of engine compartment) off when they are frozen and see why they won't move.
    The response you have gotten from your dealer is, unfortunately, fairly typical. They don't want to try to fix anything unless it throws a code or they can see it while it's broken. You might consider letting them know you will keep their response, or lack thereof, in mind next time you want to buy a car.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Hard for the dealer to remedy something they can't replicate. I'd suggest checking the weather forecast and leaving the car with the dealer overnight when it's forecast to be cold enough, so they can start the car up cold in the morning.
    toyotechwv likes this.
  4. Downeaster59
    Yes, I park outside. No garages available!
    I live in south central Maine. Not near the coast, but we get snow and rain every now and then. However, January has been unusually dry, and a fairly long cold and dry spell has just ended. The problem seems to have to do with temperature, not humidity. When the temp is over 25 or so (as it is now), the wipers work fine.
    If I feel adventurous, I'll check out that black plastic cover.
    One other unrelated thing I've seen. My Prius' mpg readout is usually 2-3 mpg higher than the result I get the old-fashioned way after I fill up and divide the miles I've driven since the last fill-up by the gallons I've just put in. That may be typical . When I had a Civic Hybrid, its mpg readout was always 1-2 mpg below what I got by the old-fashioned method!
  5. tumbleweed
    4,067
    692
    Eastern Oregon
    This is typical of the Gen3 Prius (i.e. they all do it) usually about 3 to 4% high. Toyota's way of trying to make you happy. . Enough of us have checked this out to know that the "old-fashioned method" is telling you the truth. Interestingly the Gen2 Prius was pretty close.
  6. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    My wipers have worked down to -16F, no problem. When it is that cold up here it is usually very dry however.
  7. Downeaster59
    I've never seen this happen with any car I've had before. I may have to leave it with the dealer overnight and let them catch it in the act. Then, perhaps, they can see what's going on. We're having a brief warm spell today - fog, drizzle, and 45 degrees. But it should be back to normal next week. It only happens when the temp is below 20, but that happens a lot here this time of year! If anyone else has experienced this, I'd love to hear from you!
  8. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I just found this thread by searching for "wiper". Why? Because when I got in the car this afternoon the front wipers didn't work. First time this has happened to me.
    The car was cold soaked to 23 F. I turned the car off then to ready again, but still a problem. The rear wiper was working. I looked up the fuse location in the owner's manual, pulled the cover off and determined that I couldn't pull the fuse without a tool (but I did push against the fuse panel a little). When I turned the car back on the wipers worked.
    On the way home I stopped the car to drop something off, then drove to an empty parking lot to reinstall the panel cover (took a few tries). When I turned the car on the wipers were unresponsive again. I reached down and pressed up on the panel and when I tried again they were working. :-(
    I'll be checking their operation each time I drive, going forward. I work very near a dealership, so if I can reproduce the problem ome morning I'll bring it in.
    - Chris
    P.S. - I'm quite sure this isn't a black plastic cover issue--there clearly was nothing even trying to move. Clearly an open circuit at some level.
  9. Downeaster59
    Well, this could be what I'm dealing with.
    The weather here has been very mild these past couple of days, but winter is returning. If the cold stays around, I'll bring my car to the dealership on Monday and let it sit there overnight, so that they can see for themselves the next morning. They are willing to get me a vehicle to use while they have mine.
  10. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Please keep us posted. Since the car lives in a garage I don't use the wipers much first thing.
    It does not seem to be a common problem. I'm thinking it might just involve "seating" the fuse panel somehow.
    Friday morning update:
    Wipers failed then worked then failed on the way to work. Went to the dealer instead, were inoperative as talking to the service writer, then started up on their own as we talked!
    They've parked it outdoors to cold soak. Temp is currently in the teens.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    What a bizarre problem. Can't wait to find out what it is.
  12. maoira
    maoira Junior Member
    79
    St Paul, MN (formally from San Diego, CA)
    I have a 2011 and I recently encountered the same problem. My car had been sitting out overnight in -10 degree weather and the wipers did not start... AT ALL. I had to drive an hour back home, luckily it didn't snow and I didn't need them but my rear wipers worked fine. Another time previous to that it didn't work when I sprayed my windshield so I had to stop the car and wipe off the window... seconds letter the wipers worked. It's so weird.. and extremely dangerous in MN winter conditions!
  13. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Well, nothing to report.
    Cold soaking the car in 15 degree weather for four hours didn't work. The service writer drove it around for 20 minutes as well.
    At my request they changed the fuse.
    The wipers worked fine all the way home (single swipes every few miles to test them).
    We'll see what the weekend brings.
    Chazz8 likes this.
  14. PaJa
    PaJa Senior member
    678
    116
    92
    Czech republic
    Looks to me as a wiper fuse problem. Keep us posted.
  15. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I have nowhere to go today but did a successful single swipe of the wipers in the garage this morning (25 ° F in the garage).
  16. Mendel Leisk
    41,814
    That's my experience too, coming from an '06 Civic Hybrid. Pretty much the only thing Honda did right with their hybrid, but yes: if the Civic displayed something like 5.0 liters per 100 km, when I calculated it might be 4.9. In other words: very close, erring slightly on the pessimistic side.
    With our Prius OTOH, if it's displaying 5.0 (units per above), calculated usual comes in at 5.4. :rolleyes:
  17. maoira
    79
    After a night shift at work and my car sitting in the freezing cold, the wipers once again did not work. Called Toyota and was told to bring it in, of course it had been sitting in a warm garage for close to 30 mins. On the drive there it decided to work. Toyota didn't do anything, but the service person told me that they would call HQ Monday to see if there has been similar problems and will see the course of action then.
  18. Downeaster59
    I had planned to take my Prius to the dealership yesterday so it could sit overnight for the service people, so they could catch my front wiper issue "in the act". Well, yesterday has other plans, so I didn't get to the dealership.
    I've done some more experimenting in the meantime. Previously, when the wipers didn't work right away, I turned them off and tried again a couple of minutes later. I tried turning them on and leaving them on. On cold mornings, there is a 30-60 second delay before they begin to work. Once they begin, they work after that. When the temp is above 25 (F) or so, they work right away, as expected. I still plan to get my car to the dealership soon.
  19. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    That confirms my experience (the delay). I had tried a few times (for a few seconds at a time) on the drive to the dealer. It wasn't until I left them on while talking to the service writer that they came to life.
  20. maoira
    79
    After another NOC shift and the anxiety of driving with no wipers on wet snowy roads I got my Prius to the dealer with the wipers not working. They already had planned to replace the windshield wiper motor going just by word alone, but now I actually got to show them that the wipers do not work. They'll have the car for at least 3 days, I'm looking forward to finding out what is the cause of all this.
    spiderman likes this.
