Eco Mode, Driving Modes - using a lot more lately
Discussion in 'Gen 3 Prius Main Forum' started by cycledrum, Feb 3, 2013.
  1. cycledrum
    cycledrum PSOCSOASP
    8,246
    1,202
    NorCal
    Tell ya what, these driving modes, especially Eco, work great. In heavy, stop and go traffic on the freeway, I just pop it into Eco mode to smooth things out and de-stress. Eco mode is good for starting out on cold mornings with heater on.
    Power Mode can be great for a short merge onto highway from a stop. I'm using Power mode lot less lately. Also noticed with heater on and cold engine, switching into Power mode can cause gas engine to fire up immeiately. Don't like that :eek:
    Wonder if I can make better use of EV mode. I'll try it more, but most times it says 'can't do it right now' :)
  2. BZzap!
    BZzap! Senior Member
    1,607
    878
    I guess the EV mode is ok for silent running in parking structures and such. One thing it will do is limp you to a fuel stop if you happen to run out of gas. I guess that's the point of having it available. I'm sure there will be other comment on this feature. Stay tuned.
  3. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    I tend to stay in ECO mode about 98% of the time. Force of habit.
  4. BZzap!
    1,607
    878
    Same here. Can't see the point of letting the ICE run at stop lights.
    JMD likes this.
  5. Mendel Leisk
    41,814
    I just leave them all off, leave it in Normal. Like the pedal response better.
    OceanEyes likes this.
  6. Ragin Cajun
    Ragin Cajun Junior Member
    52
    I tend to use normal most of the time also.
  7. BZzap!
    1,607
    878
    The lazy throttle in ECO mode can be a little annoying but in heavy traffic I think it's a better choice. Normal mode is probably a better option while on the open road. I have a tendacy to be a fuel minder and do a lot of "In-Town" driving. At that, I manage a pretty constant 51ish MPG.
  8. mad-dog-one
    mad-dog-one Prius Enthusiast
    1,181
    421
    Whereabouts Unknown
    I haven't and do not plan to try limping to a gas station in EV mode and don't think it would work. My theoretical understanding is that electric drive is disabled in the Gen 3 Prius, as soon as the ICE receives a computer prompt to start.
  9. RaZa
    RaZa Member
    480
    93
    i love eco mode. easy for me to maintain 55mpg even with mostly highway. pure city i easily get high 50's or better. i coast a much as possible especially 42 or under when i can coast in ev. up coming red lights are always a welcome opportunity for gas free driving.
    i still don't understand what the ev button is for though. i can engage ev mode pretty much whenever I want when doing 45 or under, so I don't get what the button is for... usually if the car is not already in ev mode and i press the button it just complains that it can't do ev mode right now (which is why i wasn't in ev in the first place)... whatever
  10. retired4999
    2,652
    627
    Eau Claire, Wi.
    It's mostly for just moving in and out of the garage or store parking lot and ect. :)
  11. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    i use the ev mode to shut the ice sooner at a stop
  12. 3PriusMike
    3,100
    2,419
    Silicon Valley
    The ICE will shut off a stop lights in every mode (assuming car is warmed up)
    Mike
  13. tankyuong
    1,555
    662
    Central MO
    sometimes it takes longer in other modes to shut the ice off but pushing the ev mode tricks the computer to do it sooner
  14. Mendel Leisk
    41,814
    I've found I could turn the engine on/off by just ticking the cabin temperature up/down. Quite predictable.
    I don't think ECO mode has any effect on engine shut off. As far as I know it's main effect is to increase gas pedal travel, and it just was too much for me: found I was starting to tromp the gas to compensate.
    James Battista and OceanEyes like this.
  15. OceanEyes
    OceanEyes Active Member
    527
    424
    Southeastern Connecticut
    Same here - for me it was easier to get a "feel" for how the Prius works...:)
  16. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    It doesn't increase the gas pedal travel throughout the full range, just the first half. What did you find objectionable about tromping on the gas?
  17. BZzap!
    1,607
    878
    I drive mine in ECO all the time with the objective of keeping my fuel consumption as low as possible. After all, isn't that what the Prius is all about? The lazy throttle in the ECO mode is a learning tool not a detriment. Probably the best way to prove that is to run a full fuel tank in both modes (ECO and Normal) and make a comparison, especially if you drive in a lot of traffic. It would be interesting to see the results.
  18. eseerc
    eseerc Junior Member
    53
    Central PA
    Semi off topic, but is there a proper way to switch in-between these three modes or can the switch happen at anytime (i.e. while moving) without any kind of damage to the vehicle?
  19. retired4999
    2,652
    627
    Eau Claire, Wi.
    I think it also changes things in the climite control system to get better mpg. Probably not a hugh difference, but a little anyway!
  20. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    It transitions very smoothly. There's little you do to make this car hurt itself.
