2011 Prius ran out of gas
Discussion in 'Gen 3 Prius Fuel Economy' started by mel82pem, Feb 4, 2013.
  1. mel82pem
    mel82pem New Member
    I am hoping someone here can help me. I made the horrible mistake of running out of gas in my prius and had to have it towed home cause dealership was closed. I was preoccupied and missed the flashing gauge on the gas. i realized something was wrong when the car wouldn't accelerate. i pulled onto a side road and tried coasting to the gas station but my battery dropped to two bars and the electric steering warning light came on and the car wouldnt move i pulled over called a friend and they came and added about a gallon of gas. i tried starting the car and now all the warning lights are on and the "ready" light is not on, if i try to put the car in D or R a message comes up saying "put in p position before starting". I had my friend get some more gasoline and add it about 3 gallons total and still had all the same messages so had it towed. My biggest concern is did I destroy the battery? I read some posts that this is a feature that the
    prius does that prevents you from harming the battery and that the dealership just has to clear the codes. Another thread said if I dissconnect the negative terminal on the battery in the rear that would reset the codes is this true and how difficult is it to do for someone with no automotive experience. I would appreciate any insight and advice.
    JMD likes this.
  2. Whiteyprius
    Whiteyprius Active Member
    389
    105
    North Carolina, USA
    Yeah - Others of us have done it - accidentally, or trying to push our Prii to the limit! I ran out of gas when my '08 was new on about the second tankful! I'm sure the F-150 that gave me some gas is still snickering. My '08 now has 109K miles, and still no battery problems. If you are still getting odd messages from your lights, I'd see a dealer ASAP - And they'll probably fuss, and say your warranty could be in jeopardy, etc. Just let 'em talk. Ask them to do a reset or whatever it takes, and chalk it up to "experience." The car's too smart for it to have done damage.
    BlackBerry 9930 ?
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Open the hatch, remove the spare tire cover & tray. Next remove the right small panle. This will give u access to the accessory battery. It take a 10mm wrench. Disconnect the 12v neg lead (its the black 1). Wait a min & then re-connect it. Try powering up now. If all went well ur ICE should turn on at which point u can re-tighten the 12v neg lead & cover everything back up
    Silver Pine Mica and JMD like this.
  4. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Whenever I've gotten that message, it was because I tried to power up the car with the driver's door opened (or cracked open). Are all the doors closed when you've done this?
  5. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    This is why you should fill up at 2 pips! I do not understand why Prii jockeys try to get the last possible drop out of your tank! It just leads, well, to exactly this sort of post!
    Just fill at 2 pips, you will NEVER have this problem!
    lar.smith42 and JMD like this.
  6. tankyuong
    tankyuong Senior Member
    1,555
    660
    Central MO
    only the dealer can determine your fate............but the battery can be tested tho if its damaged beyond repair
  7. JimboPalmer
    12,470
    6,867
    Greenwood MS USA
    If you run out of gas:
    Do NOT try to run on electric to the gas station. If the HV Battery gets too depleted to start the engine, even the dealer has no battery charger, he has to request it from Regional.
    Do NOT try to restart it until you have add 3 gallons. If the computer sees too many "tried to start with no fuel" events, it sets a code and you have to tow it to the dealer.
    Me, I get gas when it says to. Twice was enough to learn my lesson.
  8. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    Silly what were you thinking.
  9. boppo
    boppo Active Member
    799
    138
    Owego, NY
    I thought the gen3 would not move after the gas was gone?
  10. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    It can until the traction battery get too low
  11. Mendel Leisk
    38,753
    Try the disconnect/reconnect of 12 volt as described above, AND add more gas, at least 2 more gallons, to the 1 gallon already put in. Hopefully that'll solve it. If not, hie the to the dealership, to see what they say. In future, well, you know...
  12. jelliottf
    jelliottf New Member
    Perhaps you know the answer to a question I've wondered about when the gas gauge starts blinking. I would normally think I don't have much further to go before I run out of gas, so I consider the blinking light an emergency situation (it doesn't happen often).
    Last night I filled the tank when at the blinking light level. The tank took 9.3 gallons to fill up. I know that the capacity of the tank is 11.9 gallons. Simple math tells me that there were still about 2.5 gallons in the tank when it was being recorded as empty. If I take a conservative guess as to how many more miles I could go with that 2.5 gallons by assuming 40 mph (Prius III 2011), it would appear to give me 100 miles more.
    Is this correct? Does the blinking light, or even one bar, give you a comfort level that you need not worry about rushing off to the nearest gas station?
    Thanks.
    Jeff
  13. Mendel Leisk
    38,753
    My comfort level is to fill up any time the gas gauge is below half and I'm passing my station brand. Works a charm.
    GrumpyCabbie likes this.
  14. fuzzy1
    10,175
    Best quantitative answer is in the first post of this long thread:
    [WARNING] Running out of gas (Gen III)
  15. SuperchargedMR2
    SuperchargedMR2 Diehard Rams Fan
    673
    179
    Vancouver, WA
    This is how I feel too. I've never understood why so many Prius owners want to run the tank down to fumes, what does that prove? I always laugh to myself when I see someone putting gas in a car on the side of the road. Do people feel weird for filling up when the tank is at 1/3 or 1/4 of a tank? It's not good for the fuel pump to run the tank down to fumes either. I always fill up at between 2-4 bars if I'm driving by a station that I use. To all drivers everywhere ....... fill up when you are at 1/4 tank!!!! Don't be an idiot, fill up more often and save yourself any aggravation. ;)
    GG707, lar.smith42 and GrumpyCabbie like this.
  16. bwilson4web
    15,528
    In my case, curiosity. Knowing how it works, I have more options for when and where to fill-up. Given there can be significant gasoline price differences so over the years, it often saves a dollar or more every 2-3 weeks. It also lets me decide if I can defer a fill-up to meet schedule or need to take time to top off. This also means driving after midnight when open gas stations can be far between, I can again make informed choices.
    bennela and fuzzy1 like this.
  17. JimboPalmer
    12,470
    6,867
    Greenwood MS USA
    Bob, that is a reason to Run out of gas ONCE. Not to drive to fumes each tank.
  18. bwilson4web
    15,528
    • 2.1 gallons remain after 'Flash'
    • Reset tripmeter and use miles/MPG to figure out how much remains
    • My bingo limit is 0.5 gallons
    bennela likes this.
  19. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It seems to be that the cheaper your petrol, the more likely you are to run out.
    I also notice the last few posters suggesting filling up at 1/4 tank are Canadians. Quite sensible.
  20. bisco
    49,524
    no sense of adventure. unless they're wearing skates.:cool:
