My 30k service tomorrow -- on my dime.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by jayrider, Jan 1, 2013.
  1. retired4999
    2,652
    627
    Eau Claire, Wi.
    If the cabin filter is the same as in my 2005? I have washed it in a sink with warm water and with a small amount of dish soap, be gentel it is fragile. pat dry, let air dry. I have not looked at my 2012 yet, do not know if it is the same or not. :)
  2. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    I use the Fram with Charcoal added, you can not wash them, just tap the dirt out. After a time however, the Charcoal dies and the filter needs to go!
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Pat! Clean up that red wire in your engine compartment. :p
  4. KK6PD
    4,003
    946
    118
    DUH....busted!
    F8L likes this.
  5. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    It must be a lot differnt on a Gen III. I have 100,000 miles and have been around alot of dirt and leaves. I have replaced the filter 3 times. It has never looked like that. I replace it when it no longer filters the smell of a skunk. It is my understanding on the Gen III that it is only used when you press the clean air button.
  6. Bill Norton
    Bill Norton Senior Member
    2,214
    745
    MONW, Ks.
    2019 Prius
    L Eco
    Judgeless said: This carbon filter? Its purpose is when you press the clear air button that it only filters the air in the cabin of the car?
    ____________
    For the record: the cabin filter is always filtering outside air coming into the cabin. Even when OFF is selected there is flow from the car's airspeed.
    When the Recirculate button is selected air is then coming from the passenger foot well and not passing through the cabin filter.
    I have been told by a chemist that the carbon versions can filter out stink compared to the stock dust filters, but the carbon gets saturated in a few weeks and you then have a stock filter.
    If you see stink ahead press the steering wheel mounted Recirc button in the center on the right side.
    Practice. Do it without looking. Skunk season is approaching....
    The 'Clean Air' switch (left of the AC button) is to turn on the " Plasmacluster ", (® of Sharper Image) which is 'a negative and positive ION Generator' located in the drivers vent. It only stays active for a few minutes, turns on the AC and increases the fan speed. (this is how it operates on my Gen3 Level IV).
    RTDM as they say. It's in your Owner's Manual. Broken Engrish and all.
    The Plasmacluster ® makes small snapping sounds and AM/FM interference,, sometimes.
    But on the plus side of using it, I don't have bad dreams anymore, women flock to me and I lost 40 lbs. !!!!
    Codyroo and ftl like this.
  7. retired4999
    2,652
    627
    Eau Claire, Wi.
    and reversed baldness! :D
  8. The Dude
    The Dude Member
    197
    32
    Phoenix
    Just replaced my cabin filter and it was full of small leaves and debris...so I call no BS. Replaced with a Fram, perfect size and fit, and appears to be significantly better quality than OEM. Also replaced my engine air filter with a K&N, pretty slick! I couldn't believe how cheap the OEM cabin filter appeared to be...
  9. The Dude
    The Dude Member
    197
    32
    Phoenix
    Wait a min, what is the "clean air" button??? Am I missing something? I know of re-circulate and outside air, is there another mode that uses the filter?
  10. Chris S
    Chris S Active Member
    323
    111
    Gilbert, AZ
    I stumbled on a few threads addressing this after my initial confusion, info is scattered... As Bill Norton explains above, the clean air button makes the filter into a "scrubber". When you press it, the fan increases and sucks the recirculated air through the filter more than normal. It has a timed cycle, I think I read 3 minutes. This is supposed to further clean the cabin of pollen or allergens. The whole idea is cool but still confuses me when I try to figure out the hvac system.
  11. Michael King
    Michael King Member
    72
    33
    Raynham, Massachusetts
    2018 Prius Prime
    I read the manual. Chris has described it (Better than the manual). The Manual doesn't really have a use case for it defined. It's just "there"
  12. Bill Norton
    2,214
    745
    MONW, Ks.
    2019 Prius
    L Eco
    As I understand it The Plasmacluster ® Button ( aka clean air button ) is a negative ion generator located in just the drivers vent. And it does not 'scrub', does not effect the cabin filter in any way, but creates an ion charge in the air which makes air borne particles cling to surfaces. The dirt does not go away, it just sticks to everything more than normal.
    Plus it provides all the magical properties mentioned above !!
    Retired4999 may be right. I have been needing hair cuts more often since using the The Plasmacluster ® !!!!!
    And as I understand the cabin air filter, all outside air passes through it. When Recirc is selected the filter is not in the air circuit.
    On mine sometimes (?) it will go into Recirc and it always turns on the AC. I always then press the Outside air button, turn off the AC and slow the fan down. This way you get all the magical benefits without a MPG hit !!
    I use it at first hint of boredom while driving and have to restart the cycle every ~3 mins.
    But the benefits !!!! Oh,,,, the benefits ......
    Chris S likes this.
