1000 mile tank
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by crewdog, Apr 9, 2012.
  1. lensovet
    2,615
    496
    Burlington, NJ
    as discussed in some other threads, the last pip starts blinking when there's around 2 gallons left :)
  2. arek
    arek Junior Member
    97
    How the F did/do you do that?
    I have a 62 mile round trip commute!
    Please do tell!
  3. rogerv
    rogerv Senior Member
    1,639
    317
    Simi Valley, California
    Had my first experience with more than 1K miles on a tank of gas. I had two pips left at 1025 miles, and put in 9.1 gals, resulting in a calculated 112.6 mpg. The display showed 120 mpg (8.5 gals used), with a lifetime of 83 mpg at 11025 miles on the odo. EV/HV ratio is 29/71. Usually I get somewhere in the 800+ range, but did less freeway driving this time and stayed in EV mode more. I'm happy, especially with the prices going up since I filled up.:p
  4. 3PriusMike
    3,101
    2,421
    Silicon Valley
    Only 1000 miles? I just hit 2063 miles on this tank.
    Mike
    chesleyn, lensovet and F8L like this.
  5. usbseawolf2000
    usbseawolf2000 HSD PhD
    14,487
    3,002
    Fort Lee, NJ
    Dang, Mike. You still have about half the tank.
  6. 3PriusMike
    3,101
    2,421
    Silicon Valley
    I think I'll probably get some gas in the next few weeks sometime. :)
    Mike
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    My display looks like the inverse of that one. I have 13% EV miles. Hahaha
  8. rogerv
    1,639
    317
    Nice going, Mike! We need another thread for the higher EV users who hardly use any gasoline. This could be the equivalent of the 200K and 300K mile clubs on PriusChat. Of course, this thread was for us lowly 1000 mile per tankers.:) If only I didn't have to drive on the darn So Cal freeways!:(
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    We already have similar competition lists for 600, 700 and 800 mile clubs as well as a top 20 mpg records list. I never got around to adding one for the PIP because of the complexity of charging regimes. Someone should make one though. :)
  10. plugable
    plugable Junior Member
    59
    Rancho Cordova, CA
    Only 2063 miles on your tank so far? My last tank was 3447 miles..... prius 3400 mile fill up.jpg
    Tracksyde likes this.
  11. 3PriusMike
    3,101
    2,421
    Silicon Valley
    If my commute was just 6 miles longer I could charge at home and work and get more EV miles sooner. :)
    Mike
  12. mrbigh
    3,686
    699
    Long Island, NY
    My jaw just dropped to the floor :eek:
    lensovet likes this.
  13. usbseawolf2000
    14,487
    3,002
    Fort Lee, NJ
    The EV ratio is impressive. What's more impressive is the efficiency breakdown of both fuels.
    149 MPGe on electric miles (15% charging loss added). 155 MPGe with 10% charging loss.
    54 MPG on gas miles.
  14. lensovet
    2,615
    496
    Burlington, NJ
    So what's the avg speed on those miles? 15 mph lol?
  15. ElectronFlux
    ElectronFlux Junior Member
    32
    Mars
    I've gotta get me one of these!
  16. bisco
    52,849
  17. plugable
    59
    Rancho Cordova, CA
    Yeah, having a 20 mile round trip commute, and being able to charge at work has worked out pretty well for me.
    3PriusMike likes this.
  18. raimix
    raimix Member
    204
    33
    Long Island NY
    My ratio is about 12% EV 88% HV.
    Until I wiped out ~1500 EV log it was 11%~12% going back and forth.
    My pattern.
    About 2500~3000 miles a month.
    Charge once a night during weekday, and about 1.5~2 times during weekends.
  19. plugable
    59
    Rancho Cordova, CA
    More like an electrifying 20 mph......so what's your point? :)
  20. phvdriv3r
    phvdriv3r Defender of the Glass - Lemon-ed a 2012 PHV
    127
    30
    Was doing around 1600mi on a tank for a couple months when charging at home and work... commute was only 18 mi and one way was slightly downhill, other way was the opposite. Took the streets vs highway and averaged about 40 mph. Finished before fueling up again with readout showing ~165mpg on the car. Haven't done that since moving to a different workplace, now averaging 60mpg if I'm lucky. If I could do it again, I would have just kept my 2010 Prius 4, or just waited and got the C if I really needed something else. The cost of either (base or advanced) just doesn't make sense unless you're really milking all the electric you can out of the car.
