Failure to start, dash lights blinking
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by slade, Feb 7, 2013.
  1. slade
    slade Junior Member
    I drove my 2005 Prius to work and parked, left it overnight, then the next night went to take it home and the fuel and gear lights are blinking, and the car won't start. Any help?
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    How old is ur accessory 12v battery? This would ne my first check
  3. slade
    slade Junior Member
    Unknown - I've had the car for 1.5 years, so at least that. I'll put a volt meter on it and check it out.
  4. cwerdna
    cwerdna Senior Member
    12,545
    2,125
    SF Bay Area, CA
    Make sure you check it either right after you're in the bad state or after the car has sat overnight or MANY hours (BEFORE you put the car into READY mode).
    If it's still the original, it's almost surely toast.
  5. slade
    slade Junior Member
    3.1 volts, no idea how it ran down like that. Got a jump and got home, battery is on a trickle charge, but I take it I should get a new one? Does anyone know why it drained down so fast like that?
  6. cwerdna
    12,545
    2,125
    SF Bay Area, CA
    Wow! If it doesn't hold a charge, you're definitely due for a new one.
    BTW, the Prius has no dedicated starter motor and the ICE (internal combustion engine) isn't started by the 12 volt. So, you will NEVER have symptoms of a starter being slow to turn or be unable to turnover. Instead, weird stuff like the above happens.
  7. slade
    slade Junior Member
    The car won't start without the 12 volt battery, but the 12 volt battery doesn't power the starter? I really don't get where they were going on this one.
    I ordered a new battery and put the car on trickle charge for the night.
  8. cwerdna
    12,545
    2,125
    SF Bay Area, CA
