Front tow hook
Discussion in 'Prius c Technical Discussion' started by KMAN4190, Feb 10, 2013.
  1. KMAN4190
    KMAN4190 Junior Member
    57
    Hello. I took plastic cover off front bumper and tow hook screws in. Where is the hook? I assume its stored near spare tire ? I have not taken tire out so can't say for sure. Thanks
  2. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    Yes.
  3. KMAN4190
    57
  4. kingnba6
    kingnba6 Active Member
    1,018
    242
    NY
    use the tow hook for a side mount license plate? JMD! lol
  5. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    Just in case - check your manual - I think (as a Gen 3 Owner - not the "C") - the towing of any Prius is not recommended due to the risk of the damage of HSD.
  6. twblalock
    twblalock Junior Member
    The removable towing hook is for emergencies only, like pulling the car out of a snowbank or a ditch. You couldn't tow the car with it; it isn't even centered on the bumper.
  7. Les_PL
    317
    249
    Gdynia, PL
    Yes - I realize this. BTW - in most cars known to me the towing point isn't centered either front or rear :)
  8. TomasV
    TomasV Junior Member
    52
    Haddon Heights, NJ
    Is the bumper cover for the hook is removed with like a flat head screwdriver? Or by pushing it on one side and then it pops out like on other cars?
  9. Mendel Leisk
    41,955
    Think I used a flat blade screw driver on our 3rd gen. It's kind of easy to mess up the paint. A wider putty knife would be good.
  10. Mendel Leisk
    41,955
    Careful prying with my trusty/rusty Swiss Army knife blade worked just now.
    TomasV likes this.
  11. PriusNeckBeard
    PriusNeckBeard Active Member
    376
    211
    Cincinnati
  12. RRxing
    RRxing Senior Member
    2,556
    1,829
    NEPA
    Most of the repair info in the repair guide say to cover the screwdriver tip with tape to help prevent messing up the paint.
  13. PriusNeckBeard
    376
    211
    Cincinnati
    i.e. put a roll of electrical (?) tape in your trunk for some-day. K.
  14. ILuvMyPriusToo
    ILuvMyPriusToo Senior Member
    780
    518
    Outside Philly, PA
    2024 Prius Prime
    Maybe just put the tape on now so you don't forget? That screwdriver is too big for much other that prying off wheel covers, and the tape would protect them too.
  15. Mendel Leisk
    41,955
    Does the drill of:
    1. Grip wheel cover through openings at 3 and 9 o'clock.
    2. Pull hard.
    3. Fall on your butt, hopefully with wheel cover.
    No longer work?
    fuzzy1 likes this.
  16. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Supposedly, you can use an old credit card or similar, to insert and pry out the tow hook cover.
  17. fuzzy1
    10,603
    It still works great for me!
