Exclamation Mark , problem , no error messages
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sergo, Feb 5, 2013.
  1. bequa
    bequa Junior Member
    26
    Tbilisi, Georgia
    Warning lights are gone, problem was the wiring, actually just 1 tiny wire disconnected .
    The car gets average 55MPG .
    Thanks to all again .
  2. jimmy bean
    jimmy bean New Member
    Newmarket Ontario
    Hey! Over a decade later, if you happen to see this, do you remember what the wire was and where it was?
    I'm having these same symbols show up after i slid off a curve and smashed my side door. It ran fine afterward, but the next day I got both the symbols you mentioned (though the error code is different).
  3. dolj
    dolj Senior Member
    8,516
    4,323
    Wellington, New Zealand
    Hello and welcome to Prius Chat.
    I wouldn't hold your breath hoping that that wire will solve your problem too. There are probably 200 conditions that could illuminate the Master Warning Light.
    You alluded to having a code but didn't mention what that code is. If you were to share the code, you might get some useful help with it.
  4. jimmy bean
    Newmarket Ontario
    thanks. My code is p0a75
  5. Brian1954
    Brian1954 Senior Member
    2,368
    953
    South Central PA, USA
