How to get really, really, really bad MPGs
Discussion in 'Gen 2 Prius Fuel Economy' started by nerfer, Feb 9, 2013.
  1. nerfer
    nerfer A young senior member
    2,507
    235
    28
    Chicagoland, IL, USA, Earth
    First, let me say that I am an experienced Prius driver. I have a ScanGauge and know the 4 warmup states, I have an EBH and my grill is blocked. My tires are at 40/38 psi. In mixed driving in the summer I have no problems getting 55 mpg averaged over 3 tanks. In the winter I rarely turn on the heat in the car unless the windows need defrosting. But look at this picture:
    So how do you do something like this?
    Step 1: Live someplace cold enough that it doesn't get above freezing for days on end (and sometimes gets to 0'F/-17'C).
    Step 2: Live 2.4 miles from work, so the engine never gets to operating temperature.
    Step 3: Go home or out for lunch every day, for more short trips on the odometer.
    Step 4: Get a job designing railroad GPS equipment that requires occasionally road tests, the tests consisting of driving 10-20 mph with frequent long stops.
    Step 5: Happen to do 2-3 hours of this testing in the worst snowstorm to hit our area for a year, so the tires were slipping and sliding, and the defroster needed to be running on high the whole time.
    Driving conditions:[​IMG]
    ydpplqbd and DadofHedgehog like this.
  2. acausedelle
    acausedelle Hypermiling Through Campus
    Green Lake, Wisconsin
    Wow, that almost seems unreal to me. I live in Wisconsin, so I'm even colder than you are. My tanks are around 46-48 mpg currently, although I've only owned a prius for about a month. Guess you should take the prius on longer trips!
    nerfer likes this.
  3. nerfer
    2,507
    235
    28
    My next tank was 48.6, similar weather (except no snowstorm), but radically different driving - pretty much all longer trips, and speeds were mostly 20-60 mph. And on the tank above, I did manage to pull it up to about 33 before I needed to refill.
  4. ursle
    ursle Gas miser
    1,049
    192
    NH
    Imagine driving a hummer?
