setting codes with OBD II console?
Discussion in 'Gen 3 Prius Technical Discussion' started by chuckg3, Feb 15, 2013.
  1. chuckg3
    chuckg3 New Member
    17
    Space Coast
    Hello! After searching and reading, I still have not found the answer to this question:
    Is it possible to set codes ( such as killing the reverse beep) from a "console" in an OBD II program on a laptop? I haven't found a good explanation of the messages/codes used in scangauge or Torque - and I don't have either of those. What I have is a free program that runs on a laptop, OBDWiz.
    Thanks!
  2. vincent1449p
    vincent1449p Active Member
    894
    331
    Singapore
    Hi chuckg3,
    Besides SGII or Torque, you can also try this program developed by Jerry if you have the ELM327 cable.
    2010 - Help! Disabling Reverse Beep | Page 9 | PriusChat
    Vincent
  3. chuckg3
    chuckg3 New Member
    17
    Space Coast
  4. chuckg3
    chuckg3 New Member
    17
    Space Coast
    (y) It worked! I am tempted to drive around the block in reverse just to celebrate!
    In case somebody ends up here after a search, this is what I found:
    using OBDWiz software, navigate to the "console" screen. You enter commands in the little box at the top, replies from the car show up in the big black box. Type the following:
    AT H1
    AT L1
    AT SP 6
    AT DP
    AR CAF1
    AT SH 07C0 (( possible you may have to drop the lead zero, if OBD responds with ? type AT SH 7C0 ))
    (( these codes are from your laptop to the OBD adaptor, telling it how to talk to the car. These all start with AT for attention, which is an ancient tradition started by Hayes modems Next we talk to the car))
    21 AC (( car replies with mumbojumbo, should end with a 00 if beep enabled ))
    3B AC 40 (( tell car to turn off beep. might be some reply ))
    21 AC (( ask car agin, should end with 40 to say beep disabled. My car had same response as before disable))
    ....And, that is all! two minutes if you type slowly.
    Infini likes this.
