Found these "parts" next to my spare tire, any ideas???
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by The Dude, Feb 18, 2013.
  1. The Dude
    The Dude Member
    197
    32
    Phoenix
    I was checking the air pressure on my spare earlier and found these just sitting next to the tire. One is a white clip looking piece about 1.5" long and the other is what appears to be a cover of some sort and it measures approximately 3.25" long and 1.5" wide.
    Any ideas what these are???
    Input would be appreciated.
    Btw, 2010 II is what I have. Thanks everyone. 2013-02-17_23-43-53_941.jpg 2013-02-17_23-44-12_515.jpg
  2. elobster
    elobster Lobster
    Adelaide, South Australia
    i-Tech
    Hi Dude,
    I'm not sure about the clip, but the black rectangular cover was fitted into a matching hole in the large plastic bin, that is placed over the spare wheel.
    I removed mine as the hole forms the handle for lifting up the bin to access the spare wheel.
    I didn't replace mine, I put it in a box with my wheel covers.
    Cheers, Steve
    The Dude likes this.
  3. The Dude
    The Dude Member
    197
    32
    Phoenix
    Thank you Steve. Glad to know that it's not a "critical" performance component! Now about that plastic clip...man this thing's absolutely full of plastics...sad really
  4. El Dobro
    El Dobro A Member
    7,086
    3,263
    IIRC, the black plastic cover is for access to the hatch release if the 12V battery goes belly up.
  5. The Dude
    The Dude Member
    197
    32
    Phoenix
    So, it's not the part elobster described???
  6. El Dobro
    El Dobro A Member
    7,086
    3,263
    Nope. If you look through the tray where the hole is, you'll see the manual release for the rear hatch. That's so you can get to it while the tray's still in the car.
