Safetyconnect - does this work when travelling in Canada?
Discussion in 'Gen 3 Prius Audio and Electronics' started by timriley, Feb 20, 2013.
  1. timriley
    timriley Junior Member
    29
    San Diego and Calgary
    I have Safetyconnect in my 2012 Plug-in Prius. I'm planning a road trip to Canada. Does anyone know if Safetyconnect road-side assistance works while driving in Canada? I called Toyota and the rep claimed that Canada is not covered, but then I found literature (well, for Lexus safetyconnect customers which I assume would be the same as Toyota's) saying that Safetyconnect is not guaranteed to work in Canada but that roadside assistance would be provided 'if' the safetyconnect is able to make a connection while in canada (assumably in the more southern low-lying cities since it's satellite-based?). If it's based on the same XM technology in the car, I'm thinking it might work: my US- SiriusXM receiver actually works when driving in much of CAnada...
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I highly doubt it uses XM. I've never heard of mobile XM radio transmitters.
    I'd imagine it uses GPS (that will work anywhere in the world) and the cellular network to carry any voice and data. If you have no US cell coverage in Canada, and there's no roaming agreement in place, the cellular part won't work.
    I've driven to Vancouver BC when I lived in WA. Maybe a few miles past the border, I lose AT&T signal and end up roaming on Rogers (IIRC).
  3. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Safety connect uses a cell connection which is part of the car afaik.
    I don't believe it is available in Canada so if that's the case I doubt it would work up there but am not 100% sure.
  4. Turdblossom
    Turdblossom Junior Member
    28
    Kentucky
    Call Safety Connect at
    800-331-4331and ask.
  5. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    timriley and cwerdna like this.
  6. cwerdna
    12,544
    2,123
    SF Bay Area, CA
    And there's more to it
  7. ggood
    ggood Senior Member
    2,436
    517
    Houston, TX
    In other words, good luck!
  8. timriley
    29
    Ah, thanks for the info! I guess it'll be hit and miss then depending on which Canadian cities have a roaming agreement with the car's cell...
