How does the average mpg work?
Discussion in 'Gen 2 Prius Fuel Economy' started by windstrings, Jan 26, 2006.
  1. windstrings
    6,280
    378
    Central Texas
    I'm still a bit confused.. the manual doesn't spell it out too well. I have an 06.
    The average mpg in the consumption screen reflects what?
    1. The present average mpg for the "current" tank of gas?
    2. or Average mpg for the lifetime of the car?
    Isn't there a way to tell average mpg of the lifetime of the car? or was that something of the past?
    If this is for the current tank... do you have to reset it? or does it reset whenever you open the gas cap "or what resets it?"
    thanks....
  2. Frank Hudon
    Frank Hudon Senior Member
    4,147
    only for this tank, no it automatically resets when ever you add more than 4 gallons. Life time only on your spreadsheet.
  3. windstrings
    6,280
    378
    Central Texas
    Thanks Frank... and btw.. I appreciate your correspondence since I have been on priuschat. We haven't talked much one on one, but I appreciate your input.
    frank, do you know how it knows you put at least 4 gallons in?....I'm just trying to figure the logic behind that...
    I guess if you top off your tank with less than 4 gallons, it will totally mess up your average reading?
  4. maggieddd
    maggieddd Senior Member
    2,090
    Boston
    it would only mess up your reading for the previous tank. I mean it would be for a tank and a half. Not really messed up
  5. windstrings
    6,280
    378
    Central Texas
    Thanks Maggie, I haven't seen much of you lately unless you've been lurking where I didn't see?......
    Do you know how the system knows?.. maybe its just electronic and the guage resets the average if it moves so far at once? "from a fillup"
  6. maggieddd
    2,090
    Boston
    Ohh, I've been around, a LOT.
    Not sure exactly if there is some kind of sensor or somehitng else that resets the MPG, but I know that it doesn't reset right away when you pass the 4 gallon mark. It resets iteself after you drive a mile or so.
  7. windstrings
    6,280
    378
    Central Texas
    Interesting!....
    Anyway.. sorry I"ve missed you... I've been a bit preoccupied with trying to finagle getting my last car, and every day I come home to about 80 to 100 emails!.. I'm gonna have to weed some of those out!..
    Anyway... catch you later and thanks..
    btw.. I was sure hoping to see your penquin take up cigar smoking.. too bad :(
  8. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    I am convinced that the '06 DOES NOT reset the average MPG indicator when you fill up. That is based upon my car, a friend who also has an '06, and experience with an '05. There is definitely a change. I believe if you don't touch the reset button, you are getting a lifetime mpg average but the miles indicated are for the tank.
    Example: A few days ago I put 8.9 gallons in my 2006. The miles indicator on the consumption screen reset to 0 in 100 to 200 yards. My mileage was 39.8 MPG before fillup. It stayed at 39.8 for miles. In a 7 mile drive home, starting with the car warm after getting gas, I had only 50+ MPG segments showing in the display. The mpg average indicator only went to 40.1 mpg. Now being an engineer I calculated that (39.8*361 + 55*7)/368 = 40.1 (I had 361 miles on the car when I filled it).
    This is verified by my friend at work with 1200+ miles and 4 fillups. And when I drive Barbara's 2005 Prius shortly after she fills it, I see an average mpg indicator that changes around a lot as the engine goes from cold to warm or as you go up and down hills. My 2006 (with 60 miles now on that tank) has been rock steady with miles of driving (cold, hot, high mileage, low mileage) needed to budge the average mpg indicator by .1 mpg. So it acts as if it is averaging against the 400+ miles on the car rather than the 60 on the tank.
    I had been driving an Audi with an average mpg indicator for 5 years before this one. I know what to expect. There is a change from the 2005 and it is not mentioned in the manual. My car is an 11/05 build date.
    - Tom
  9. windstrings
    6,280
    378
    Central Texas
    Your right.. I finally filled up my tank this eve.... you can reset the odometer A or B, but as far as the Average indicator, it continues to monitor as if you never filled your tank UNLESS you hit reset in the lower right corner of the screen... then it start over at 0.0 as if you first bought your car.
    So basically you get a choice.... leave it alone and you get lifetime or at least an average since the last "reset"..... however you can reset it anytime you want.. I don't even think its related to whether you just put gas in or not.... I think you can reset it anytime you want.
  10. Frank Hudon
    4,147
    ok it's starting to look like Toyota went back to the cumulative MPG readout on the 2k6 from all reports. The Classics were cumulative and the 2k4-5's weren't. So I stand corrected on this. Don't tell the wife she'll want a new one.
  11. Tom_06
    609
    142
    Only the "Average MPG" does not reset. The "miles" next to it resets after a few hundred yards of driving. I wonder what genius came up with that one? I suspect it is not an intentional change as the manual does not say anything different than the 04-05's.
    - Tom
  12. Rattiemama
    Rattiemama New Member
    69
    San Francisco Bay Area
    Ok I know this is slightly off topic . . . but I have a 2005 and the first few times filled it it reset automatically. Miles and MPGs to 0. However, it has't reset automatically for several months. If I don't hit reset, it just keeps adding to the last tank. Anyone else experience this? Incidentally I allways fill up to a full tank, and usually when I have 1 or 2 bars left. I usually put in between 8 and 9 gallons.
  13. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    why would it not know??? that is a very strange question.
    if you are worried about it, you can manually reset it yourself using reset on the comsumption screen. if you do plan to track your lifetime (LT) mileage, (it is highly recommended) you should use one of the trip computers since it provides accuracy in 10ths.
    also my reasoning why you should reset on every fillup. it would be impossible to track incremental mileage data. actually, not impossible, but very inaccurate. by resetting your mileage on every tank, its easy to calculate your mileage for short durations. eventually, the LT mileage indicator will be useless. it will move so slowly that it will no longer be a good inidicator of whether the Prius has changed its performance level
  14. windstrings
    6,280
    378
    Central Texas
    I asked that question before I put my second tank in..... I didn't know how it worked and I coudn't find anything in the manual about it.
    the question I suppose was strange because it was common knowledge, except not for me.
  15. windstrings
    6,280
    378
    Central Texas
    yea.. that was real trippy, "sorry.. nothing personal Tripp!" that I saw my gas guage go up after about a minute or so..... that tells me its not purely mechanical.. but there is some type of computer something going on.... nothing like I've ever seen.
  16. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    i also did not know about the mpg's now being LT or whenever you reset it on the 06's. i think this is a bad idea. having the mileage reset on every tank full is the way to go. this enables you to compare mileage from tank to tank. LT readings would eventually become useless except over a large range of time. if something is going on with my Prius that is lowering the mileage, i want to know about it as quickly as possible. i never wait for my tank to reset, i just manually reset it the same time i reset my trip meter when i get gas
  17. windstrings
    6,280
    378
    Central Texas
    I wonder if mine would reset automatically if I waited a few minutes after fillup?
    I too agree that although its cool to know what the lifetime mileage is, its not too usefull.... whatever was going on back when, you can't change or fix now and if you did you couldn't see the results anyway against 50 fillups.
    the more you get instant feedback the better.
  18. pgorbas
    pgorbas New Member
    I am wondering about this - I have now filled up Twice :) ( average mpg of 2 fillups was 42mpg - but it has been in the 40's here in Kansas City ) When I put in gas and the car resets ( 1st time it reset after about 1 tire rotation, tne 2nd time did not fill up until a full mile was driven ). When it "resets" the miliage goes to zero, but the mpg remains at it's last reading - if the mpg is just for this tank, then the mpg should reset to zero as well?? ;)
  19. windstrings
    6,280
    378
    Central Texas
    Ill have to look again, but I think you hit the reset button in the lower right of the MFD to reset the average mpg.
  20. geologyrox
    geologyrox New Member
    513
    EDIT: because I broke that rule about responding before reading all the other answers first.
    I'm mad! I wish I hadn't hit the reset button at the first fillup. Guess it's better than having it accidentally reset many miles down the road. And like y'all said, it's not like lifetime MPG is anything more than a novelty after a while anyway.
