85+MPH MPG
Discussion in 'Gen 3 Prius Fuel Economy' started by El Dobro, Feb 24, 2013.
  1. El Dobro
    El Dobro A Member
    7,079
    3,259
    For those of you that have commutes, etc. that you drive at over 85+ mph, what kind of gas mileage are you getting?
    walter Lee likes this.
  2. GasSaver1
    GasSaver1 Member
    220
    South Florida\Long Island NY
    42-44mpg
    I have done a few NY-FL trips at that speed
  3. GasSaver1
    GasSaver1 Member
    220
    but this is at 85, the faster you go the more it hurts. I pull about 50mpg at 65 47mpg at 70
  4. El Dobro
    El Dobro A Member
    7,079
    3,259
  5. walter Lee
    1,126
    376
    Maryland
    In mid-April last year, I set my 2010 Prius cruise control at 80 mph going eastbound on a Ohio Superhighway( with a 70-75 mph PSL) - basically I filled the Prius up with gas and then drove it at 80 mph in the rain on a superhighway until I got the first beep and the last bar on the fuel gauge starte to blink - which at that point I drove into the most convenient gas station to get a fillup. The Prius MFD estimated its FE at 48 mpg but I calculated at the gas station that over 440 miles @80 mph that my Prius was getting about 44 mpg using 10% ethanol 87 octane regular gas. The driving temperature was about 65 degrees Fahrenheit and it was raining cats and dogs all day -- driving conditions were dismal. I was using Yokohama Avid s33d - iirc the tires were slightly over inflated at 38 psi front and 36 psi rear.
