Buy a 2010 Prius Four with 123,000 miles?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by TwoUnderPar, Feb 25, 2013.
  1. TwoUnderPar
    TwoUnderPar Member
    78
    72
    Newbie here at PC. Not a newbie in life though... 56 years old and just retired (y) . Anyway, I'm considering purchasing a 2010 Prius, one owner, lots of miles on it. Looks great. At this point in time, I do not yet know it's full service history. The price seems reasonable as it appears I could probably get it bought for $14,000. What do all of you maintenance experts have to say about this?
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Welcome aboard. Wow, that is a lot of miles. Could it go many more miles? Sure, but a lot depends on how it was serviced and treated. Personally that price seems a bit on the lofty side all things considered.
    Let us know what the service records are like when you get em.
    [edit] what model is it and is there any options?
    Blu-ray likes this.
  3. drunkin master
    drunkin master Contributing Member
    394
    103
    92
    Los Angeles
    well if its a four then it sounds about right. I would see the maintenance records or at least a carfax before doing anything.
    Keep us updated.
  4. The Dude
    The Dude Member
    197
    32
    Phoenix
    Have you considered a "lesser" model with lower miles at around the same cost? I think right now, lower miles is more important than some options.
  5. frodoz737
    frodoz737 Top Wrench
    4,721
    2,517
    33
    Dude is correct. The difference between a Level II and Level V are the buzzers and whistles, otherwise the vehicles are identical. With the "change oil every 10K, rotate tires every 5K and no other maintenance required" attitude most Prius owners have, and not knowing the "real" maintenance history, stay away from that car. Like people, it's not the year model, but the mileage that kills ya. I am 54 years old for the record.
  6. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    I was about to reply the opposite (regarding years and miles).
    It seems as if the traction battery does fine with many miles. I suspect that the accumulation of years takes more of a toll there. With that many miles in a short time I bet most of them were at speed with little stop and go wear and tear.
    Lacking maintenance history you'd want to change most fluids right off the bat, but I'd use the general anxiety about battery life out there as leverage to get the price reduced one or two thousand and go with it.
    In this area things rust with time. I'd be far better off with this than an eight year old with 80,000 miles on it.
    xPETEx likes this.
  7. frodoz737
    4,721
    2,517
    33
    Good point on the rust factor. Although there seems some argument the benefits of miles over time, the battery is still out of hybrid warranty at 8yr/100K miles, unless it originated from a CARB State @10yr/150K miles. Even then 27K miles left on a $14,000 vehicle....Nope, I say pass. Two-Under where are you and what state did the Vehicle originate?
  8. Baggiebird8
    Baggiebird8 Junior Member
    17
    Nr Cardiff, Wales, UK
    Hi.
    Might be OK with full service history (oil changes every 10k miles would be essential and none missed!!). I would look for a slightly lower 'spec car with 80k miles or less, but similar age - if within budget.:)
    Interestingly, I just did a search on Auto Trader UK and there were 4 Gen III cars over 100k miles listed at £8-10k which is similar money (well 12-15k $) . Highest mileage car was 149k miles with full Toyota service history, almost certainly an ex company car. All were T spirits (top UK trim level basically). One was at a Toyota approved franchise. Still says a lot for the cars though doesn't it?!?!
  9. TwoUnderPar
    TwoUnderPar Member
    78
    72
    Thanks to all of you for the comments so far. Yes, the question that has been going around in my mind is "years old" or "mileage". I live in eastern Iowa, USA so salt/rust/corrosion can be a problem. This car is a Four (IV) so it has the heated leather seats, which I would prefer. It also has the shiney alloy 15" wheels.
    Snow storm today (again!) so I won't be checking in with the dealer right away. I'm still considering several possibilities and have obviously made no final offers to any dealers yet. I did drive a 2011 Prius Two (II) with 71,000 miles last week. My budget is in the $17K - $18K range so the high mileage IV is actually under my budget...
  10. Netbook
    Netbook Junior Member
    47
    17
    I have close to 105,000 miles on my 2010 Prius IV. I have had zero issues and strongly believe that I will get 300,000 miles with very little repairs. I am not sure if $14K is a good price or not but I predict the car will last many more miles without issues.
    cwerdna likes this.
  11. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    If you're serious about buying this car, check the service history via the Toyota owner's portal. Not too long ago, I looked at the service histories of a few 100k+ Gen III Prii and a number of them were at the dealer for very high oil consumption (1 qt/1k). In every instance, the car was traded right after that visit...so beware. If I recall correctly, all of them had relatively on-time oil changes with 0w20.
  12. Netbook
    47
    17
    Are you claiming that after 100k+ that you found a ‘number of them’ that consumed ‘1qt every 1k miles’? REALLY!!!!!!
    My Prius has 104,000 miles and I get my oil changed every 10,000 miles as recommended from Toyota. The Prius holds less than 6qt of oil. Are you claiming that many 2010 Prius cars have zero oil after 6,000 miles of driving? Why do people post stuff like this? Total BS!!!!
    People that post this BS should be banned from Prius Chat. It is all lies.
  13. The Critic
    3,193
    2,333
    CA
    A number of the used 100k+ mile Prii I found on autotrader, after looking up their service records in the owners portal, were brought to the dealer for an oil consumption complaint shortly before they were put up for sale.
    Never did I say that it is a common issue, nor did I imply at all that every high mileage Gen III has/will have an oil consumption problem. I simply stated that the OP should check that this car is not one that may have been traded due to a documented oil consumption problem.
    And yes, I suppose if you have a serious oil burner and you did not check the oil, you would not make it 10,000 miles. ;)
    edit: Take a look at this thread: What to do to slow down oil burn? 2010 Prius - Bob Is The Oil Guy
    It certainly can happen, and at a far lower mileage as well.
  14. Netbook
    47
    17
    Maybe I read your post wrong. You looked at a few Gen III Prius cars with over 100,000 miles. To me few means more than a couple and less than many or a lot. Let’s call it 5-6 cars. You claim a number of them had HORRIBLE oil issues. They burned (1 qt/1k) as you put it. Or a full engine of oil every 6,000 miles. A number of them implies more then 1 and maybe more. So at least two. That is 33% or 1/3 of 2010 Prius cars burn crazy amounts of oil after 100,000. According to your post.
    There is a 100,000 thread for Gen III Prius owners. Not one of maybe 50 people complained about burning oil. I think your facts are way off.
  15. The Critic
    3,193
    2,333
    CA
    I don't think you misread my post. I took a RANDOM sample of high mileage Gen III Prii. I believe I looked at 3 cars, and 2 of them were major oil burners supposedly, per their documented service history. It has been a while since I looked at this so I'm going by memory here, but the point is - it stuck out in my mind.
    Regardless, it is such a small number that it would be unreasonable to assume that this is a widespread issue. I only mentioned the issue because I wanted the OP to check and make sure that this car wasn't one of those.....even though the chance is quite remote.
    I don't know why you're taking this so personally.
  16. fotomoto
    fotomoto Senior Member
    5,639
    3,815
    So. Texas
    You're retired so you have time on your side to shop for a great deal. Use autotempest.com or the like. Within two minutes I found a one owner 2010 for $2k more but with HALF the miles:
    Toyota Prius, 2010-2010 - AutoTempest.com Used Car Search Engine
    Unless you're located in the expensive areas like SF or NY, you should be able to find something comparable.
  17. HybridSpin
    HybridSpin Junior Member
    If this is the blue one at the Toyota dealer in Iowa City, they quoted me $13300 for that car.
    BTW I found another IV with half the miles for $4000 more
  18. TwoUnderPar
    TwoUnderPar Member
    78
    72
    Critic - Thanks for the tip. I did not know that "anyone" could check out a service record at Toyota Owners portal. I will check that out for sure.
    HybridSpin - It's not a blue one, but the Iowa City dealership is within my search range and I am including them within my searches.
    Thanks. Learning something everyday!
  19. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    You can get a new Prius C for your budget. Consumer reports says it is the most reliable car.
    For a few grand more a new regular Prius if you shop a good price.
    Buying a used car try and get one under 70,000 miles and 3 years old but through a dealer is not much cheaper than new.
    This article from Time magazine supports my statement.
    The Smoking Hot Market for ‘Gently-Used’ Cars | TIME.com
  20. deunan
    deunan Junior Member
    27
    PDX
    I got 2010 prius with 124,000 miles and with no problem. Since i drive about 1,500 miles a week, i get oil change about month and a half. If that owner drive that much, he most likely took good care of car. All I did to my car is oil changes, trans-axle fluid, and coolant for both.
