Tire problem
Discussion in 'Prius c Main Forum' started by orangePruisC, Mar 3, 2013.
  1. orangePruisC
    orangePruisC New Member
    Sure hope someone has some insight... Had a nail in a tire, got it fixed. Went to check air pressure, as I started to take off the cap air started gushing out... What could have caused this? A valve problem? Thanks in advance
  2. Mendel Leisk
    41,904
    Did the fix involve tire removal from the rim? If so, and they put in a new valve, likely the new valve needs adjustment. There's a simple tool that can fit into the valve stem, locks onto the interal part and is used to screw that part in/out of the valve stem. It's likely that part just needs screwing in a little further, and the hissing will stop.
    Here's one example, they're readily available:
    Victor 4-way Tire Valve Tool | Canadian Tire
    (The tire place should that did the flat repair should really do this. And if my suggestion doesn't help I'd get back to them.)
    firstrival likes this.
  3. B. Roberts
    B. Roberts Hypah Milah! Ayuh.
    691
    212
    used to be "Glacial" Maine and now FL
    Call the shop that fixed your tire. They definitely had one of those "oops!" moments. They should fix it for you.
  4. orangePruisC
    The thingy inside was loose, simple fix. Thanks
    ztanos likes this.
  5. Burchie
    Burchie Junior Member
    22
    Corona, CA
    schrader valve. Fun trick to play on someone.
    orangePruisC likes this.
