Stock 15's to Stock 17's ?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Tim Powell, Mar 4, 2013.
  1. Tim Powell
    Tim Powell Member
    42
    25
    Central Florida
    I bought a set of new 17" Prius Five wheels and will be taking them in tomorrow to have Bridgestone Ecopia EP422's put on thanks to the advice I've gotten on this forum. I ordered new center caps from the dealership today and they will be in tomorrow too, but my questions is will the lug nuts from my 15's work on the 17's? I would have asked the dealer today, but just thought of it!
  2. massparanoia
    massparanoia Active Member
    697
    467
    Virginia
    I wouldn't see why not. Bolt pattern and threads should be the same.
  3. armoredsaint
    armoredsaint Anti-Eco Company Car
    92
    28
    what about your speedo reading?
  4. Mendel Leisk
    41,865
    I have the 17''s (Canadian Touring model). Here's a lug nut pic:
    As an alternative to the stock 215/45R17 a few people have been using 205/50R17. It's virtually the same diameter as 195/65R15. AFAIK, Ecopia Ep422 is available in the alternate as well as stock 17" size, while Michelin Primacy is only available 215/45R17.
    F8L likes this.
  5. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    When I purchased my used Prius 5, 17" wheels, they came with lug bolts and the center caps. I'm sure I used the ones that came with the factory 15" wheels.
  6. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    I assume he will put the proper low profile tires on the 17 inch wheels - then the overall diameter will stay about the same. Hence, no major change in the "speedo".
  7. F8L
    19,011
    4,083
    Grass Valley, CA.
    Yes. The lug nuts are the same. They also work on the Lexus CT200h wheels.
  8. Tim Powell
    Tim Powell Member
    42
    25
    Central Florida
    Thank you very much! I am going with the 205/50/17 tires all thanks to the F8L for all the tire info you've so kindly shared here.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    My pleasure. I just like to try stuff and hopefully help others make a sound decision.
    Remember what I said about the EP422 being a fairly mushy tire compared to say the PureContact or Primacy MXM4. :)
