DRL's or not??
Discussion in 'Gen 2 Prius Main Forum' started by magnumrtawd, Mar 4, 2013.
  1. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    I recently purchased a 2008 Prius touring.
    Reading my manual it says if there is a light senser on the lower left corner of my dash my lights will come on with the proper daytime brightness. It appears they are full intensity all the time.
    I read a post stating no U.S. cars have DRL's . Which is true.?
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Yes. That is true. Only the US spec 2012 & current have oem DRLs.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    and to clarify, all the Canadian models have it because of the requirement as many other countries do to. So if you have a US spec car only 2012+ have it. For Canadian models, they all have it.
  4. fuzzy1
    10,483
    And while the cars are a bit different, the main manual appears to cover the English speaking portions of both countries.
  5. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Haha.....I though about including the Canadian spec. I think the UK spec might also be the same.
  6. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Thanks for the reply.
