CD changed jammed
Discussion in 'Gen 2 Prius Audio and Electronics' started by THF, Mar 6, 2013.
  1. THF
    THF Junior Member
    71
    MO Ozarks
    We just got a 2004 prius. (Don't know if c or v, but it is a reasonable size so assuming v.) The CD changed appears to be jammed. Everytime the vehicle is started it runs the changed, trying to play the disc. It will not accept any discs put into it; pliers have to be used to extract the disc. (Carefully of course.) Any ideas? It also reads a "CD error."
  2. JimboPalmer
    12,470
    6,878
    Greenwood MS USA
    The Prius c, Prius v and Prius PHV were all introduced in model year 2012. All 2004 Prius are just Gen 2 Prius. I have asked a moderator to move this request there.
    EDIT: Your profile claims it is a 2001, so it may be a Gen 1 Prius.
  3. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    **Moved**.
    We had a similar problem - both w/ our gen 1 and gen 2. There's a small gear on the roller that moves the disc in and out of the changer. That gear cracks over time and causes the unit to fail to eject. I ultimately replaced the head unit in my gen 2 w/ a unit pulled from a bone yard via eBay.
    See 2004 JBL CD changer - CD stuck. Replace with same or one with AUX? | PriusChat for some photos of this part.
