Driving in the ECO Mode?
Discussion in 'Prius c Fuel Economy' started by South_Bay_Surfer, Mar 25, 2012.
  1. Wayne M. Baker
    Wayne M. Baker New Member
    I get 61 mpg
  2. Bob Hahn
    Bob Hahn Wingman08
    386
    118
    Jacksonville, Fl
    Mine is always in Eco, too.
  3. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    Maine
    No, but then it won't give you more torque to turn it off either, so you might as well leave it on.
  4. RocMills
    RocMills Active Member
    789
    277
    Las Vegas, Nevada
    I think ECO mode is good to use while you are learning or getting used to the car, but after that I don't see the advantage. I can control the gas pedal myself and am not a lead foot, so I don't need ECO mode to decrease the sensitivity for me. And I also don't want or need ECO mode taking over my HVAC controls.
  5. Rob.au
    Rob.au Active Member
    960
    441
    Sydney, Australia
    i-Tech
    For me, I want to be in the lower ranges anyway, so ECO mode gives me finer control of that range. Then if I want, I know the rest is there if I put my foot down.
    Also during our summer I need its influence over the HVAC. That's the only reason my economy has remained vaguely acceptable! I'm actually looking forward to the temperatures coming down here so I can get off the air con.
  6. Stefiie
    Stefiie New Member
    I recently purchased a Prius C Four and seem to be getting better MPG on normal mode. I thought Eco mode would result in better MPG, so I've had it in Eco mode since purchasing. But I switched it to normal, and the MPG immediately started going up. I will continue to test it out. I haven't gotten over 52 mpg since I drove on the first tank of gas the dealership provided. I wonder what type of gas they used :/
  7. Mendel Leisk
    41,236
    ECO modes pedal travel seems excessive. In theory increasing pedal travel needed to get a reaction from the engine might save you gas. But in practice I've found Normal mode's pedal travel is not at all touchy, very easy to modulate. ECO mode is good for exercising your right leg muscle, I guess.
    RocMills likes this.
  8. Cherhonda Murchison
    Cherhonda Murchison New Member
  9. Cherhonda Murchison
    I have only had my prius for less than a week. I have not experimented with the ECO mode. Would the freeway (I95) be a good place to try it out? Thoughts anyone? I'm thinking city limits would not be good.
  10. bisco
    51,795
    it makes no difference, try it anywhere. you'll feel a difference in pedal travel vs acceleration. it also affects your hvac, in the city or on the highway. the difference insn't earth shattering though, go for it!(y)
    minkus likes this.
  11. goinskiing
    goinskiing Active Member
    202
    187
    Meridian, ID, USA
    2018 Prius Prime
    It really seems that it depends on your driving habits and where you are driving. Myself, I have noticed that I get the best MPG in ECO mode. My commute is 50/50 City/Freeway.
  12. Castanea
    Castanea Member
    39
    27
    Iowa
    I wasn't sure whether Eco mode affected the heat as well as the AC, so I did a little experiment: Start the car in Normal mode, put the climate control on Auto, turn the temperature all the way up to "Hi." As the engine warms up, the fan gradually increases its speed until it is running at its maximum. Then switch to Eco mode. The heater fan immediately goes down two or three levels.
    I'm still experimenting with Normal and Eco mode, and haven't figured out which I prefer. But I don't like being cold! I've learned to wait until the cabin has started getting comfortable before shifting to Eco.
  13. ztanos
    ztanos All-around Geek!
    3,339
    1,150
    40
    Cumming, Georgia
    AC controls cold and hot... so it would work the same way for both, just depends on what temperature you set it at.
  14. jennifer valdez
    jennifer valdez New Member
    United States
    2011 Aqua
    Three Touring
    For all practical purposes just leave it in Eco mode. ECO mode reduces throttle response to help you accelerate slowly and smoothly. It also changes air conditioning response to reduce the drain on engine power. Driving in this mode will improve fuel economy.
  15. Mendel Leisk
    41,236
    I find normal just fine. With third gen, the pedal travel in ECO, at least for me, is too large a motion to be comfortable. I actually found myself aggressively tromping the gas to compensate when in ECO, turned it off about 6 months after purchase.
    ztanos likes this.
  16. Castanea
    Castanea Member
    39
    27
    Iowa
    Jennifer, welcome to the forum!
    Off-topic, but with a 2011 Aqua, you might have one of the oldest "Prius C"s around here.
    Back on topic: I mentioned in my previous post about turning it off in order to get maximum heat. Since then I've narrowed it down a bit; so long as it is above freezing outside, I find that I am okay with the level of heating that one gets in Eco mode. When it is much colder than that, not so much. So for now, I think I will be running in Eco except when it is too cold.
  17. ztanos
    3,339
    1,150
    40
    Cumming, Georgia
    Ditto. My MPGs went up when I turned off ECO.
  18. Prodigyplace
    12,517
    11,739
    Central Virginia
    Eco mode changes the climate control too. On the Gen 4 Liftback you can set Eco mode for climate control separate from drive mode.
  19. Mendel Leisk
    41,236
    The above comments are my experience with 3rd gen. OTOH, it's been reported that throttle response has been shifted towards the aggressive by roughly one mode, in the 4th gen. Then maybe with 4th gen I would be an ECO mode fan.
    Bottom line, I would try them, see how they fit.
  20. Prodigyplace
    12,517
    11,739
    Central Virginia
    The Prius c is 3rd Gen anyway.
    On the Gen 4 I prefer Normal mode because drive mode also affects Radar Cruise control responsiveness. Eco is too sluggish.
