How to upload songs to the in-built Hard Drive?
Discussion in 'Gen 2 Prius Audio and Electronics' started by seymoria, Mar 6, 2013.
  1. seymoria
    seymoria New Member
    India
    Hi all.
    Kindly please advise know how to upload songs to the vehicle's built-in Hard Drive (shown as 'HDD' on the navigation).
    Since my car is a Japanese version, there is no manual. An English copy I downloaded from these forums does not contain any reference to the HDD (only CD Player and Radio).
    Thanks for your help.
  2. dhancock
    dhancock 2 Prius Family
    357
    40
    Hamburg, NY (Buffalo area)
    I don't believe that the older Pri had a HDD nav system. That is a relatively recent (2012) option. Even then, I doubt very much that songs could be uploaded to the nav system drive.
  3. seymoria
    seymoria New Member
    India
    Thanks for your reply.
    In my car, I can toggle between a CD Player and an 'HDD' through the 'DISC' button. I presume its a hard drive.
    This item (shown as 'HDD' on the screen) has many loaded MP3 songs onto it, most of which are in Japanese language. I want delete / replace some of these songs.
    Regards.
  4. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yep. No Gen 2 (04-09) US Priuses came with any hard drive, HDD based nav system nor any means to upload MP3s to a hard drive or any other internal storage.
  5. seymoria
    seymoria New Member
    India
    Ok. Thanks for your two replies.
    I will try the Prius 2010+ forums. If that Prius has an HDD, maybe someone can advise on my query.
  6. dhancock
    357
    40
    I suspect that your car's entertainment system is different from the one's that we have in the US. I gather that you purchased it used. Was it built for your market? Or was it imported from Japan as a used car. Also, it is possible that you have some sort of "aftermarket" system.
    I wouldn't bother with 2010+ forums, as that HDD is associated strictly with the Nav system - and is not accessible by the audio system.
  7. seymoria
    seymoria New Member
    India
    Yes, it was imported from Japan as a used car. Obviously not built for our market. It is also possible that this is some aftermarket system installed by the original Japanese owner.
    I posted yesterday in the Gen-III forum but my post has been deleted (maybe by the Admin due to irrelevance).
    Maybe you know of cars in the US with such feature. I can search on internet for forums on that car make.
  8. dhancock
    357
    40
    I do know that there are some current US cars with a HDD in the audio system (my Son-In-Law has a 2012 Ford Fusion with that feature - that car only has a single CD player, but it allows the driver to transfer discs to the audio HDD, so that the audio system effectively has a multi-disc player). Our 2011 Prius does have a USB input so it can effectively have a large capacity (though the interface is primitive).
    The real key to your problem is that everything is in Japanese. Perhaps you can find someone over there who understands Japanese who can work with you to find the solution.
  9. seymoria
    seymoria New Member
    India
    Thanks.
    Yes. Its a good idea to find some who can understand Japanese, though a far fetched solution.
  10. Abdul Bari
    Abdul Bari New Member
    Karachi, Pakistan
    Dear member,
    pls try this when you insert a new CD, go to the sound menu, (last button on left of the navi screen panel) you see a record button on the touch screen right bottom, if the button is not highlighted that means its not a compatible audio to record in HDD, to the best of my knowledge it accepts only CD audio not the MP3
    Pls try and confirm, if it works :)
    chathud likes this.
  11. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    751
    Delaware
    what is it with the japs? they must still be ticked cause we nuked em. they get an internal HHD, while we get a crap sound system. no ev button, and a stupid bladder in the gas tank which is only on us version cars. Wth?
    wingfeathers likes this.
