Key not detected
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Ralphshunt, Aug 31, 2011.
  1. Ralphshunt
    Ralphshunt New Member
    portland
    2011 Prius. I had a friend riding in my car that also owns a 2011 Prius. When he was in my car with his key fob in his pocket my key fob could not be detected. The solution to the problem was to remove his key from the vehicle. We eventually found we could just move his key fob to the trunk area of my car and my key would be detected. Anybody else ever experience this problem? It seems pretty dangerous because sometimes my key would be detected, we would start to drive and then get a "key not detected" message which would eventually stop the car.
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    I have seen one other post where someone else's key interfered with the driver's car.
    As for being dangerous and stopping the car, this should not happen. Once the Prius is started you can throw your key away and it will continue to run until you either stop it or run out of gas. Once stopped you will not be able to restart without the fob.
  3. ETC(SS)
    7,134
    Concur.
    It's not going to be an issue as long as he has his fob.
  4. qbee42
    3,079
    Once started, your Prius will continue to run with or without a working key fob. It was designed this way for obvious safety reasons.
  5. babybird
    babybird Member
    117
    44
    Colorado
    If nothing else, doesn't the 2011 still have the slot you can plug your fob into like on the 2nd gen models? That should override a key not detected problem since I think it bypasses the SKS system.
  6. qbee42
    3,079
    No, it doesn't. The Gen III Prius require you to hold the fob near the button to use the backup RFID chip.
  7. Mendel Leisk
    41,315
    The other day I experienced a "key detected in vehicle" warning, soon after starting out from parking spot. Alzheimers must be setting in: I can't actually remember if I stopped, shut down, and restarted, but it did go away.
    I know mechanical keys can be buggers to when they fail, say running your starter till it fries, but the Prius "touchless" ignition has some loopy foibles...
  8. Unlimited_MPG
    Unlimited_MPG Member
    218
    24
    Federal Way, WA
    Hi Ralphshunt,
    I had something very similar happen to me. Here is the thread I started a while back about it:
    http://priuschat.com/forums/gen-iii...e-troubleshooting/95292-sks-odd-behavior.html
    Here is a video I made of the issue:
  9. job
    job Junior Member
    there maybe a fix for this. i just bought my 4th prius in 6 years. the 2012 interferes with the 2011 and vice versa. just got it a week ago and told dealership i wanted to return the car. they said a brand new fix was available and this coming wednesday they will try it. let you know what happens.
  10. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    What do you mean eventually stop the car ????
    If YOU(or anyone else) stop the car ... you can not restart !!! but other than that the car will go without the keyfob !!!
  11. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    Yep. OP's assertions are wrong and who knows if they'll be back? They haven't made another post and were last seen almost a year ago.
  12. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    It's all in the car manual. The key is a radio device and can be affected by other radio devices such as other electronic keys or mobile phones. There is no safety issue as once the car is started and in Ready mode it will continue to drive without the key being in range (or even in the car) until the car is turned off.
