TRD springs, Lexus CT200h 17" wheels and 205/50/17 tires
Discussion in 'Prius Owner Photos' started by F8L, Oct 31, 2012.
  1. F8L
    19,011
    4,083
    Grass Valley, CA.
  2. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Look absolutely amazing! Take whatever mileage hit you get, the car looks phenomenal!
  3. F8L
    19,011
    4,083
    Grass Valley, CA.
    Thanks bru! :)
    It drives much better so I'm swallowing my FE pride and rolling with the mpg hit.
  4. Codyroo
    1,826
    515
    Pleasanton, Ca
    Have the MPG's settled out? How big a hit? 6 - 8 mpg?
  5. F8L
    19,011
    4,083
    Grass Valley, CA.
    I don't know for sure. My mpg was already dropping by the time I put the aftermarket 15" wheels on. I was averaging 52-54mpg then but I was driving like I didn't care about FE. Driving the same way with the 17s but cooler temps I am sitting at 49mpg. I don't think I will be able to say anything with confidence until next summer when conditions are the same as when I was testing. There are just too many variables that I cannot control now.
    I can still get over 50mpg indicated if I want to. :)
  6. a priori
    a priori Canonus Curiosus
    3,083
    408
    Chicagoland (West)
    Me, too. (But I have to get a couple of buddies to help me grab the tow rope to get the car back up the side of the ski hill.)
  7. a priori
    3,083
    408
    Chicagoland (West)
    Actually, my current tank is running at 53+, indicated, for the past 260 miles. Most of this was driving through the country at speeds from 45 to 55 mph. Good speeds for great FE, even if there are many stop signs and stop lights. On the old Toyo Proxes, I think my indicated FE likely would have been around 60 MPG, so I know I'm taking a hit on the MXM4s. (For those who haven't followed the saga, after 60K I dropped the OE Toyo Proxes 17" tires in favor of Michelin Primacy MXM4s, and they are a huge improvement, except in fuel economy.)
  8. Airrider
    Airrider Junior Member
    Walnut Creek, CA
    Was the improvement just in ride quality? (Smother, quiter on the inside of the car)
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    No. Handling and traction are much better as well. MPG takes a hit, however, the MXM4 is a lot cheaper than the Proxes A20 so it's a wash in the end. Might as well get the better performing and SAFER tire.
  10. a priori
    3,083
    408
    Chicagoland (West)
    Smoother, quieter, surer handling, better wet-weather traction, much better turning . . .
    BIG gas mileage hit. I've only been driving them through cold months, so I can't compare them to the Proxes for any other period, but the drop is somewhere around 10%. Once I've had them on for closer to 10,000 miles, I'll do a full comparison to the OEM tires.
  11. .paul.
    .paul. Junior Member
  12. Sfcyclist
    Sfcyclist Senior Member
    1,621
    376
    SF, CA
    Most or a lot of PC members seem to prefer the mpg's over the other gains from having 17's. I would say I wouldn't have have bought my car if it wasn't equiped.
    A read a lot of complaints on the Prius handling poorly yet why isn't it so obvious the 15" wheel/tire combo has a lot to do with it. I pretty happy with my combo, Persona 17's with Plus springs.
  13. Sfcyclist
    1,621
    376
    SF, CA
    Just saw the date.. :ROFLMAO:
