Arists list limited from Bluetooth device
Discussion in 'Gen 3 Prius Audio and Electronics' started by Omid Majdi, Mar 11, 2013.
  1. Omid Majdi
    Omid Majdi New Member
    Just got a 2013 Prius Two yesterday and I love it. Every single thing about the bluetooth pairing from my iPhone is amazing, except:
    When I goto the "Browse" section and select "Artists" I will get a limited list of Artists that ends at Michael Jackson. Granted I have 440 artists, but why will it not go any further down the list? I first assumed that it takes a few seconds to load the rest of the list, but after waiting a while the rest of the list never appears and it is stuck, not allowing me to browse for any artists beneath Michael Jackson.
    Is there a limit to how many artists can be loaded into the list? Any help would be greatly appreciated.
  2. Want A Hybrid
    Want A Hybrid New Member
    In my TCH I can only import the first 1000 contacts from my phone so I have more than 100 that do not get loaded, and it seems to be by alphabetical order. Maybe it's the same with music?
  3. Omid Majdi
    Yeah, that's what I'm assuming is happening, but was just wondering if anyone knew what that limit is and/or if there is a workaround for being able to access the rest of the list.
  4. batsai
    batsai Junior Member
    I have similar issues- I remember once my playlists would show correctly, but once I tapped on them, the wrong playlist would appear! Maddening- I feel your pain. What worked for me was this (and it might be overkill, but it worked):
    1. Delete the Entune app on your iPhone.
    2. On iPhone- go to Settings - General - Reset - Reset all settings.
    You won't lose any data, but will have to set some settings again- ringtone, screen brightness, etc...
    3. Download and install the Entune app back onto your iPhone. Sign in with your user name and password.
    Except for the annoying iPod startup bug that many experience, Entune and the iPod functionality has worked pretty well ever since.
    Good luck!
    iPhone ?
  5. Willco Electronics
    Willco Electronics Junior Member
    51
    Don't use Bluetooth, use the USB cable instead. Then the iPhone or iPad/iPod will display when you select source.
