Odometer accuracy vs GPS
Discussion in 'Gen 3 Prius Fuel Economy' started by Big Steve, Mar 14, 2013.
  1. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    I have seen it stated that the odometer/speedometer accuracy can be checked by comparing to the GPS. can someone explain how I would do this with my Prius' nav system?
  2. jdenenberg
    jdenenberg EE Professor
    3,938
    1,936
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Use the GPS in a Smart Phone or a dedicated GPS (Garmin, Tom Tom, ...). You need to have a system that you know is independent of the circumference of your tires.
    JeffD
  3. Big Steve
    402
    39
    Richmond VA
    Thanks, I will download an iPhone app. Anyone know of one you recommend?
  4. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Avoid curvy roads when you are making the comparison. A GPS can read little low on a real curvy road.
  5. jdenenberg
    3,938
    1,936
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Sorry, I am an Android / Windows / Garmin user and avoid Apple products.
    JeffD
  6. fuzzy1
    10,337
    Note that the displayed odometer and speedometer figures will have different errors, so measure each separately. Don't measure just one and assume the other is the same.
    xs650 likes this.
  7. Mendel Leisk
    41,013
    Just a prediction: speedometer will read about 4% high (52mph when speed is actually 50, for example), and odometer should be quite accurate (assuming you have stock tire size).
    F8L, szgabor and CaliforniaBear like this.
  8. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    My experience in a 2012 Prius Three was 1 mile high from about 30mph up. In my 2012 PIP its about 1.5 miles high from 30mph up. Checked with a Garmin nuvi 1450 which, by the way, is what I use for navigation. The Nav in the Three and the basic PIP isn't to my liking.
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    My speedo generally reads 1mph higher than my Garmin. Not sure about the odo. You'll need to have one of the trip odos displayed to see the tenths. On the same route I believe the nav & the nuvi show the same mileage. I will have to make a point of checking it on the way home.
  10. szgabor
    szgabor Active Member
    994
    175
    Oceanside NY
    That is by LAW (international law for that) it was quoted on the PC many many time :)
  11. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    Maybe, but I've had a couple of BMW vehicles that overstated the speed by about 10%!
  12. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    International in the sense that the Euro regs apply to more than one country, not that it is close to universal international law.
    There is a Euro reg that the Europeans go by, you could call that international law because there is more than one nation involved. The US regulations are different and the Euro regs don't apply in the US. IIRC, in Europe the speedometers are required to exaggerate more than they are in the US
    fuzzy1 likes this.
  13. tumbleweed
    tumbleweed Senior Member
    4,067
    691
    Eastern Oregon
    Here is a copy of the U.N. regulation that governs speedometer accuracy, it originally came out in the late 1950s. This is the 2003 version and there may be a later one but they are pretty much the same.
  14. fuzzy1
    10,337
    Do note the list of ratifying countries at the bottom of page 6. The 40 countries are heavily weighted towards Europe. No countries in North / Central / South America have joined this particular Agreement.
  15. F8L
    19,011
    4,083
    Grass Valley, CA.
    I use a mixture of My Tracks, GPS Test, GPS Essentials and GPS Odometer on my Android phone.
    The odometer is very accurate with OE tires and air pressure at 38psi on flat roads. The Speedo error varies by speed but average is about 1.5mph too fast +- .5mph. Since the speedo doesn't read in decimals it is hard to really say.
    skwcrj likes this.
