2002 Wiring Harness Fix
Discussion in 'Generation 1 Prius Discussion' started by slimfrancis, Mar 13, 2013.
  1. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    You can pop the connector out of the insulated sleeve with a screwdriver...
    slimfrancis likes this.
  2. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    thanks! i went to grainger along with 3 or 4 other places and no place had any uninsulated connectors. one store told me to do the same thing you just mentioned. grainger can get uninsulated connectors but only in boxes of 100.
  3. usnavystgc
    3,159
    990
    Tucson, AZ
    I would have easily had them all soldered by now (lol).:)
  4. bwilson4web
    16,357
    SHUUSSSHHHHH!!!!!
    I would have had them soldered to a perf board in a case so I could in the future tap and monitor various signals. It would have an RJ-45 so I could pull up to eight signals. <GRINS>
    usnavystgc likes this.
  5. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    i would have easily paid you $250 if you did solder them already. haha. i'm back in town and about to crimp them together today. i'll let you know what happens.
  6. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    i thought it looked a little empty behind my head light. i see my inverter coolant pump is missing as well. ...damn scavengers at the auction yard. hence the reason my harness was cut. luckily i got this car for $1000.
  7. 3prongpaul
    3prongpaul Hybrid Shop Owner, worked on 100's of Prius's
    956
    730
    Boulder Hybids, Boulder, CO
    Don't trust a used inverter/tranny coolant pump...pay the $$ for a new one with shiny silver/gold bracket (original had black bracket). Weak pump can cook inverter and/or tranny.
  8. slimfrancis
    slimfrancis Member
    188
    36
    New Haven, CT
    I
    thanks! i just ordered a new pump today for $120. i just finished crimping my harness back together and unfortunately there's still no lights or power getting to the dash. my 12 volt battery is good, there's continuity in my fusible link, i checked my DC/DC and DOME fuses and they're good.
    i'm not getting any current coming through any of the harness wires.
