If I do NOT renew SiriusXM, how will my radio reception be?
Discussion in 'Gen 3 Prius Audio and Electronics' started by lr123internet, Dec 22, 2012.
  1. lr123internet
    lr123internet Junior Member
    I am fine with regular old AM and FM stations, NPR related, and use of my iPhone music, but I'd like to know if I'll see a big drop in reception quality if I drop the Sirius service. Anyone have any thoughts?
    Thanks!
    -Lisa
    Rebound and JMD like this.
  2. sfv41901
    sfv41901 Masta S
    4,591
    5,293
    Palmdale, Ca
    Ur radio will work the same with or without sat radio.
  3. lr123internet
    Thanks - I thought the satellite service got reception through another way than without. So, I thought it would be different.
  4. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,180
    289
    Northern California
    AM, FM, Disk will work fine. Satellite will not work.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    The Satellite antenna and receiver is a totally different one than the AM/FM.
  6. lr123internet
    So, my question is if the reception received when NOT on satellite sounds as clear:good as the reception on satellite channels.
  7. CaliforniaBear
    1,180
    289
    Northern California
    It depends on where you are. Satellite works "everywhere", AM and FM only withing some distance of the station. "Everywhere" for the satellite has some problems in deep canyons and tall forests.
  8. jdcollins5
    5,131
    1,346
    Wilmington, NC
    What is your reception for AM/FM like now? It will be exactly the same if you drop XM. There is absolutely no correlation between the two signals.
  9. Adam Leibovitch
    498
    102
    The signal for satellite radio is much better and sends a wider range of frequencies and higher quality audio. Its also much higher quality than mp3 files, but with the stock speakers and depending on your ears it may not be very noticeable. You can do a comparison before the satellite trial runs out.
  10. Zedknepplin
    Zedknepplin semper prius
    124
    65
    162
    Georgia
    Hi Lisa,
    I did not renew either. Once it is cancelled, you get just CH1 - I believe which is basically a continuous commercial for SiriusXM. CH0 (zero) shows your unique XM codes. Every now and then I get some free sample time of a few channels. If you hold out and they call you, you can get it for less than half price, but the taxes and fees bump it back up. I mainly use my IPOD now. My Wife has a Prius 3 also and I think her Radio head unit is better than the Premium NAV unit that came with my Prius 5 - Hers even has 3d maps!
  11. RaZa
    RaZa Member
    480
    93
    If you do not renew sirrusxm apparently you loose the 3 "free" years of xm data. at least i did...
  12. RaZa
    RaZa Member
    480
    93
    I take back my previous statement. Erica here helped me get my account fixed. Anyone with 3 free years of xm data access should get just that. 3 free years. regardless of whether you have xm music or not
  13. rsg
    rsg Member
    64
    Harrisburg, NC
    During Hurricane Sandy, Sirius/XM ran the Weather Channel audio on CH1. Great idea and a potential life-saver for folks.
  14. Zedknepplin
    124
    65
    162
    Georgia
    Thanks for the info!
  15. Netbook
    Netbook Junior Member
    47
    17
    I better question is if you do not renew SiriusXM, how will your MPG’s be effected? The answer is the same. They have nothing to do with each other.
    - FM/AM uses their own antennas and local radio stations broadcast with limited range.
    - SiriusXM uses a cluster of satellites and planes sometimes to broadcast their signal to their subscribers and the unit that receives it has their own antenna.
    - The Prius uses gas to power the car.
    None of these things affect the other.
  16. prius2010II
    prius2010II Member
    278
    27
    us
    A few FM stations, z100 for example, are carried by XM. The reception on those few stations may be worse if you drop XM and tune those stations through your FM radio. Those stations will, of course, l be completely missing if you're completely out of FM range.
    Otherwise pp are correct.
  17. kyle5434
    kyle5434 Junior Member
    37
    Nebraska
    My experience with Siruis/XM is that the audio quality is significantly WORSE than MP3 - or at last the MP3's that I've created. My MP3 files are encoded at a variable bit rate that averages around 190-200 kb/s. Subjectively, satellite radio sounds to my ears like a 96-128 kb/s stream - too many "shimmery" artifacts in the audio that ended up with me abandoning the service.
  18. 13Plug
    13Plug Active Member
    581
    105
    2013 Prius Plug-in
    The SiriusXM reception in my car is by far worse than FM radio reception. When I go by a two-story building, the satellite radio cuts out. I did not renew after my three month trial, it's not worth $20 / month, and they weren't willing to give me a deal.
  19. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    If you call XM before your service free 90 day trial ends you can get Select for half price about $8 a month plus taxes or about $97 for a year. If you say I'm not sure can you do better they throw in another 3 months free.
  20. 13Plug
    581
    105
    2013 Prius Plug-in
    No, I wanted the premier package, they weren't willing to discount. Previously I had been with Sirius for 5+ years and they were always willing to give me great deals. And now they want $4 / month for online listening... I'm gone!
