Shark fin antenna which one to get?
Discussion in 'Gen 3 Prius Main Forum' started by Mrpcar, Mar 18, 2013.
  1. Mrpcar
    Mrpcar Active Member
    542
    253
    Chino Hills, CA
    Can't believe I am hearing this from my wife tonight, she is totally not a car person.
    She told me to go ahead and order the shark fin antenna for the Prius, I asked "Why?"
    She said today after she pulled into a parking spot another white Gen 3 Prius pulled up and parked to her right. She was saying to herself that she was going to walk up to the wrong car later when she get out.... When she got out there was another white Prius 3 parked to her left she said at that point she was really confused and can't tell which Prius is hers.
    She wanted to do something different to be able to tell which Prius is hers in the sea of white Priuses in southern California....
  2. swich2mac
    swich2mac Go Hard or Go Home!
    319
    Franklin, TN
    I want one as well but want to know if the OEM antenna is for am/fm only or does it also serve the satellite radio or navigation system? By switching to the shark fin, will I lose any functionality?
  3. wotcher
    wotcher Member
    403
    97
    LA
    beatsonic or vg... both are good. some argue better reception on one over the other. it really depends if you have a solar roof. if you have a solar roof, then you need to get a smaller profile shark fin.
    Mrpcar likes this.
  4. Mrpcar
    542
    253
    Chino Hills, CA
    I have solar, so which one is the lower profile? Since our car is white and the roof is black how would the white shark fin look as far as contract in color?
    TIA
  5. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    The antenna is only used for the AM/FM radio. Satellite and GPS antennas are separate, under the dash. I think the cell antenna for crash assist (or whatever name Toyota uses) is also separate, as none of them can send or receive a signal through the amplifier on the stock radio antenna.
    The shark fin will not work quite as well as the stock antenna, but you probably won't notice in urban areas.
  6. wotcher
    wotcher Member
    403
    97
    LA
    fuzzy memory. im getting old. i think the beatsonic one is larger. there are a couple of threads here regarding this issue. when i get off work and have free time, i'll dig up the threads for you.
    consider vinyl wrap the white part b/c 80% of your roof is black. its what i did. then you can get a black shark fin.
  7. Mrpcar
    542
    253
    Chino Hills, CA
    I see, that's an idea!
  8. BCP
    BCP Junior Member
    33
    Southern Maryland
    I'm not sure which is 'better' but Juiced Hybrid asks if you have the Solar Roof or not when choosing the options to buy the version they offer.
    Toyota Prius Shark Fin Antenna
  9. mnsweeps
    mnsweeps Member
    108
    Los Angeles CA
    Ebay fins from China / HK are so much cheaper but not sure of quality. They also don't ask about solar roof which I have ...what difference does it make if you have or not have a solar roof ?
  10. Mrpcar
    542
    253
    Chino Hills, CA
    Maybe due to limited space from the solar panel the fins can't extend as far?
  11. Mrpcar
    542
    253
    Chino Hills, CA
    Just ordered one from Priuschat shop, figured to give this forum as much contribution as possible. I've already ordered rubber mats, sunshade from priuschat shop prior.
    ralleia and BCP like this.
  12. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    I don't want to admit how much I spent in the shop last week when I finally ordered all the accoutrements to outfit my 2012.
    Yesterday I put all the Weathertech mats in.
    I'm just waiting on the Euro mudflaps to come in and then I'm going to schedule with a shop to put on all those external pieces.
    Still waiting on my fin to come in.
  13. Mrpcar
    542
    253
    Chino Hills, CA
    Shark fun antenna arrived from Prius shop, I ordered the solar panel white version.
  14. Mark Knight
    Mark Knight Junior Member
    31
    Grand Rapids, MI
    I ordered a custom made shark fin from priusaccessory.com, have not recieved it yet as it is custom made and painted to match car code color.
    ralleia likes this.
  15. xliderider
    xliderider Senior Member
    8,079
    3,235
    Honolulu, HI
    I wanted to install a sharkfin antenna on our Prius, but my wife said, "where will the Mickey antenna ball go?" :D
    That's how she picks out her car in a garage or parking lot. Just look for Mickey. :)
    Mrpcar and ralleia like this.
