Take out grill block before going to dealer?
Discussion in 'Gen 2 Prius Main Forum' started by PriusGuy32, Mar 19, 2013.
  1. PriusGuy32
    1,417
    514
    Harrison Township, Michigan
    My Prius is going in today to the Toyota Dealer for the two recalls.
    Should I pull out my grille blocking? Would they give me grief about it (i.e. "your inverter cooling pump is bad because you overheated it with the grill blocking and we arent covering it") ?
  2. matt b.
    matt b. Member
    251
    60
    L.A.
    Do everthing to make it look the day you drove it off the lot
  3. ETC(SS)
    7,147
  4. 2009Prius
    2009Prius A Wimpy DIYer
    2,705
    512
    63
    I guess it depends on the dealer. I never bother with removing the grill block especially since I had painstakingly zip-tied a piece of plastic to partially block the lower grill and it would take a long time to put it back if I cut the zip ties. The dealer never complained. I do disconnect stuff from the OBD port so it's available for the dealer to plug in their tester if needed.
  5. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    Your way braver then me ! I would never give the dealer a chance to void MY warranty.
  6. fuzzy1
    10,446
    While my dealership(s) have never mentioned it when I didn't take the block out, on the most recent visit (September) they removed the (partial) block without saying anything.
  7. Mendel Leisk
    41,434
    I probably would, if I ever darken their doorstep. I use pipe insulation, single strips that run the full width of the lower grill, either one or two, depending on weather. I secure with velcro tape, and it takes all of 30 seconds to remove.
  8. PriusGuy32
    1,417
    514
    I ended up taking out the grill block. I would rather err on the side of caution and not give them any reason to a.) give me grief, b.) void any warranties, c.) not perform the recalls saying that I accelerated any kind of failure.
    On the bright side, a really cute dealership shop tech shuttled me back from the Dealer to my work in a 2013 fully loaded Hybrid Camry! It was really cool (oh, the car was too) :whistle: :D
  9. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I don't remove the insulation & I don't unplug my ScanGauge. One time the Greeter asked about the insulation. No hassles, no aggravations, no problems.
