Edmunds is Showing a Spoiler Option
Discussion in 'Gen 2 Prius Accessories & Modifications' started by DonDNH, May 25, 2004.
  1. DonDNH
    DonDNH Senior Member
    1,711
    654
    Nashua, NH
    Four Touring
    I don't remember seeing this before now. Has anyone seen a Prius with the spoiler?
  2. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Yeah - look at every Prius delivered on the lot - it has a spoliler between the upper and lower rear glass :) It's there to help lower Cd. It's not studry enough IMHO for downforce/handling.
    Unless, that is, it's a more "dramatic" spoiler. Unless it improved MPG, I'd probably skip it.
  3. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    3rd party? Or from Toyota?
  4. DonDNH
    1,711
    654
    Nashua, NH
    Four Touring
  5. mikepaul
    mikepaul Senior Member
    1,763
    Columbia, SC
    This was pointed out in March, when CarsDirect.com listed it as being for late May 2004 availability.
    Perhaps it's a metal spoiler, to replace the less-than-sturdy-feeling one I think is made of plastic. I have to remember not to close the hatchback by pushing on the spoiler, because I think I'd spoil it...
  6. slowpoke
    slowpoke New Member
    48
    Ok, first of all it's a front wheel drive car. Second, it's a Prius, not a rice rocket. :rolleyes:
  7. Tempus
    Tempus Senior Member
    1,690
    Washington DC
    There is an 'extended rear spoiler' available on the JP option pages that have been linked here a couple of times. Don't know if that's it or not.
  8. mikepaul
    1,763
    Columbia, SC
  9. Mybrid
    Mybrid New Member
    172
    37
    E.P. Or. (Southern Org.)
    :wave: :wave: :wave: :wave:
    OK ya want spoiler well here ya go!
    The top pic is the extended and the bottom is the standard (sorry for the pic's messing up just click on them to see in color.).
    :computer: :wave:
  10. HTMLSpinnr
    5,339
    917
    251
    Honestly, it doesn't appear that extended to me, just that the picture was taken at a different rotation, which gives the illusion that it is longer. I'd say no more than 1" difference at most if it was extended. What benefit would 1" provide?
  11. mdacmeis
    mdacmeis Member
    133
    Michigan
    2018 Prius Prime
    I recall it being pointed out many weeks ago that the Edmonds site simply had bad data, as many others do. There is no spoiler option from Toyota. The spoiler is standard.
    The extended spoiler is being mentioned more now. It appears to be an option or Toyota aftermarket item for a few markets, but not yet in the US. The last info I saw said it was being "considered" and I believe the source was Japan.
  12. mikepaul
    1,763
    Columbia, SC
    It looks more "upswept", so maybe that allows it to catch more air and push the rear end down more?
    Assuming, of course, that pushing the rear down is part of the plan...
  13. Mybrid
    Mybrid New Member
    172
    37
    :roll: :roll: :roll: :roll: :roll:
    Yes the pic's are at different angles and it makes it harder to see the difference. I posted these as they were the closest shots and I've seen other pic's were you have to look real close to see it but I'd say rearward is 2 to 3 inch difference and some where around 1 to 2 inch in rise of arch.
    Of course that is just my two cents worth.
    :computer: :wave:
