Gen 3 Tires 195/65-15 for Gen 2 2004-2009
Discussion in 'Gen 2 Prius Accessories & Modifications' started by HighBreed, Mar 20, 2013.
  1. HighBreed
    HighBreed Member
    113
    Los Angeles/Orange Counties
    Has anyone tried to install gen 3 tires on gen 2 2004-2009 Prius? The 195/65-15 tires is slightly bigger offering half inch more road contact and slightly less revs per mile. Please chime in your experience if you have done such mod. Thank you.
  2. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    I have and the car feels fine. Lots of Prius owners use this size tire. H
  3. HighBreed
    HighBreed Member
    113
    Any noticeable speedometer accuracy issue? I would think not much since the Prius speedometer tend to be somewhat a bit faster than true speed. The larger tire will either fix it correctly or become a bit slower. Thank you for your reply.
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    205/60r15's work good too. and they look better. speedo is corrected a little as well. about the same mileage as my wife's which has oe size michelins.
  5. HighBreed
    HighBreed Member
    113
    The 205/60-15 is slightly smaller in diameter than 195/65-15-- in fact may be perfectly equal in diameter to 185/65-15, so yes, I think that's an excellent replacement. It's more sporty because you have beefier rubbers. I'd suspect it will affect your MPG as it has more road contact patch. But then again, there's too many variables like radial construction etc. Do you see a hit on MPG?
  6. 69shovlhed
    2,170
    752
    Delaware
    205/60's are a little taller than oe. as i said, mileage about the same. guess i should have said mpg... but since they're taller, it may be that the mpg is a hair better cause you go farther per rpm of the tire. i want to buy lrr tires next time i need em.
  7. HaroldW
    716
    95
    The speedo will be bang on with the 195/65/R15 tires.H
  8. MANZOOM
    MANZOOM Junior Member
    pakistan
    I changed the tyres to 195/65/15 .
    Is this effect the engine performance
    Or gear box.
  9. dolj
    dolj Senior Member
    8,452
    4,292
    Wellington, New Zealand
    Neither. It is really an illusion due to the increased diameter of the wheel.
    If you are changing to 195 mm width tyres, the correct height-to-width ratio (for a Gen 2) is 60. So, you should be fitting 195/60 R15 tyres.
    Using 65 (height-to-width ratio) tyres will mean your odometer and speedometer will be inaccurate. It will underread, if I'm not mistaken, due to the overall increased diameter of the wheel. This inaccuracy will cause the calculated MPG figures to be more optimistic than reality.
