Belt replacement
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuszilla, Mar 16, 2013.
  1. priuszilla
    priuszilla Junior Member
    texas
    I have a question for you guys here.
    I have 85k on my Gen 2 and the dealership recommended that I change out the belts in 5-10k miles. The cost would be $149
    Do I need to change this out or is the dealership trying to hustle me? I don't remember seeing that on Galaxee's list of things to do.
    Please let and me know and thanks in advance.
  2. jadziasman
    jadziasman Prius owner emeritus
    1,355
    488
    District 6
    The belt will need to be replaced at some point. If it hasn't been replaced yet after 85k miles and nearly 5 years, it's probably a good investment to replace the belt soon.
    It's not easy to replace so you might want to take it to a mechanic who has a hoist to do it for you.
    $149 is a little overpriced but that's what the stealership charges.
    An independent shop could probably do it for you for $100.
  3. priuszilla
    texas
    Hi Jadziasman. I was having the steering column and water pump recall done on my car and they said the belt has slight cracks in it. Do you think it will cheaper to have it done right now since the water pump is out?
  4. css28
    css28 Senior Member
    1,566
    443
    Suburban Detroit
    That's for them to tell you.
    If they're saying $150 now or $150 later then they're not cutting you a break.
    If they'll charge you just $100 this time they you might as well go for it [my opinion].
  5. jadziasman
    1,355
    488
    District 6
    You are probably having the HV inverter water pump replaced which is not part of the same cooling system as the gasoline engine water pump, which is belt driven.
    The dealer is trying to make some extra money. It's your call if you want to fork over some to them.
    If the $149 charge doesn't bother you, then give the go ahead. As I said, the belt will need to be replaced eventually.
  6. priuszilla
    texas
    Dealership just called back and said that I could bring it on a Wednesday when they have Ladies day. Ladies day = 15% off
    About $128.65 for the belt.
  7. priuszilla
    texas
    Jad, you were right it was the engine driving belt that was going to be replaced. :)
  8. stevelawrence
    stevelawrence Junior Member
    Interesting..
    I have 28k on my car (although it's 5 years old now)
    I was told exactly the same thing, when it went in for its recall. Get this :
    Drive belt 'has cracks' ( I'm dubious) $149
    New tires ( huh? After 28k miles) - $468
    balance and rotate - Um.. s'cuse me? If you're putting new tires on, are you saying you're gonna put them on 'out of balance' ? $128
    New battery - $430 ish.
    Rear brakes need some kind of 'cleaning' $59
    and some other stuff I can't recall.
    So, I was looking in this forum about 'new battery'. Granted - my car has needed a jump start a couple of times over this last winter, so I'm figuring that it does need a new one. However, while looking at the dealership recommendation - the new battery comes with an 8 year warranty. My car is only 4 years old. Wouldn't the OLD battery come with an 8 year warranty aswell? If so, shouldn't my 'dying battery' be covered?
    Steve.
  9. boppo
    boppo Active Member
    799
    139
    Owego, NY
    I think the 8 years is on a new latest and greatest Toyota battery that just came out. The one that came in your car might of had a year warranty.
  10. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Steve why would a brand new set of tyres need rotating.
    John (Britprius)
  11. stevelawrence
    Beats me... Sounds like a scam to me.
    Along with those 'your air cabin filter is dirty, needs replacing' = $90.
    Which is the line I got last time I went to this place...
    For a $12 part and 30 seconds of unclipping inside the glove compartment. AND... the service technician actually brought it out to show me (it had some leaf debris in it!!!). Thing is? He had... already gotten it out. And therefore had to clip it back in when I refused. Which is the same 'labour' he'd have to perform had I simply bought the $25 filter from the shelf in the service department. My mind boggles.
    So, anyway - after some research it looks like I can get a spiffy new battery for about $160 and fit it myself in about an hour (30 minutes once you've done it before). I've muddled around that area of my Prius (back from when I installed an aftermarket Sirius unit). Save myself $230 'labour'...
  12. dhanson865
    dhanson865 Expert and Devil's advocate
    851
    188
    TN, USA
    The belt is a $25 part plus labor. I did my own in less than half an hour but many dealerships will charge a 1 hour minimum.
    It probably needs to be done around 75,000 miles to 100,000 miles or a lot longer even if you like to run it until it breaks (saw pics in one thread of a belt changed at 164,000 miles).
    cracks in drive belt | PriusChat is the thread I posted my photos in and I linked to another thread with instructions on replacing it.
    Toyota Genuine Parts 90916-02570 Alternator and Fan Belt : Amazon.com : Automotive is the actual part so you can see a price.
  13. meowmeow
    meowmeow Junior Member
    SoCal
    I have a 2008 Prius and the dealership told me my serpentine belt is cracked and it would be $200 for parts and labor this morning. This is a quote from Tustin Toyota here in Orange County, CA. It's a relief I have used this site to reference what needs to get done and what doesn't need to get done. It's sort of frustrating that they're blatantly overcharging me the price of the belt itself too. They told me the belt is 100$.
    Anyone know of a mechanic in the Orange County/Los Angeles area that will do a good job of replacing the belt for a decent cost?
    iPad ? HD
  14. Britprius
    5,194
    1,918
    Any reasonable mechanic should be able to replace the belt in 15 minutes or less. There is nothing special about the fitting of the belt as in fact it is much simpler than most cars, but a little difficult to get at. It only drives one item, the coolant pump. In the UK the belt is around £8 so about $12 to $15 for the part.
    John (Britprius)
  15. nh7o
    nh7o Off grid since 1980
    1,686
    340
    Hawaii
    Call Avi's Advanced Automotive. Avi is a contributor to PC.
