12V battery - how to test it?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by tomlondon, Mar 21, 2013.
  1. tomlondon
    tomlondon New Member
    London
    I only just got my Prius and when I went to test drive it at the dealership, the battery was dead and the car had to be jumpstarted, which made me feel a little bit concerned at the time. I picked up the car a couple of days later and the dealer told me the battery was fine and didn't need to be replaced.
    I have just tested it with the meter and I got the following results:
    • vehicle switched off - 12.4V
    • engine off headlights on - 11.6V
    • engine on - 14.7V
    Since I bought the car two weeks ago I didn't have any issues with the battery. During the testing the car was still warm, having been used about 15 minutes before I tested the battery. The car is a 2010 model Prius with 47k miles on the clock. My question is: are the above values within normal range or can I go back and pester the dealer to get me a brand new battery?
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,346
    Wilmington, NC
    From the 2010 Owner's Manual:
    12.6 12.8 V Fully charged
    12.2 12.4 V Half charged
    11.511.9 V Discharged
    (Voltage is checked 20 minutes after the hybrid
    system and all lights are turned off.)
    [SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial]According to this your battery is Half Charged but in OK condition. If you only drive for short distances it is not having time to completely charge. If you do not have a battery charger to complete the charging, you can leave the vehicle in Ready mode for a few hours and let the car's charging circuit complete the charging. [/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE]
    [SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial][SIZE=3][FONT=Arial]The Prius battery charging system is very slow due to its' low current charging rate to keep from overheating the battery and causing it to gas off since the battery is located inside the cabin. [/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE][/FONT][/SIZE]
    BobStein, TsKarma and tomlondon like this.
  3. tomlondon
    London
    Thanks a lot!
  4. Bill Norton
    Bill Norton Senior Member
    2,208
    744
    MONW, Ks.
    2019 Prius
    L Eco
    tomlondon,
    If it were me, I would insist on a new battery.
    Make sure it's new, not from another used Prius. I don't trust those blokes.
    The issue is: when Lead Acid batteries are left in a discharged state for any length of time damage is done.
    Look it up.
    It's possible for a discharged Lead Acid battery to freeze and crack its case if it gets cold enough. The electrolyte has turned back to water,, or close to it...
    It is possible to bring a totally discharged battery back to life, it may test fine, but it's life span will be shorter and its capacity will be much less. You might get a surprise if you leave your car at an airport for a few weeks.
    Good luck with dealing with car dealers.... I try to avoid it... You know how to tell if a car sales man is lying?:whistle:
    TsKarma likes this.
  5. SteveLee
    SteveLee Active Member
    645
    180
    North Carolina
    I
    If you have those same readings after sitting all night and the car is starting ok, then you may be alright for a while. But the battery is weaker than when new. If after sitting all night the readings are weaker then you might want to consider a new battery while you can chose when and where it will be replaced. Good luck getting the dealer to replace it now.
    You might find this thread helpful.
    Fitting mobility 12volt AGM battery. | PriusChat
  6. Les_PL
    Les_PL Active Member
    317
    249
    Gdynia, PL
    Did you also try to check voltages in Diagnostic Mode with built-up self test?
  7. tomlondon
    London
    From what I understand, the Diagnostic Mode in Gen III Prius doesn't show the battery. I managed to enter the Diagnostics by turning accessories on and switching the lights on and off three times but I couldn't find anything on battery. I measured it with a multimeter...
  8. Les_PL
    317
    249
    Gdynia, PL
    Seems you don't have Nav/Camera display. My screenshots are attached.
    I have the following results
    • vehicle switched off - 11.3V
    • engine off headlights on - 10.9V !!
    • engine on - 14.2V
    Obviously my battery needs to be replaced. For more than two months my car was unattended in cold garage, I was at sea and my wife neglected to turn on the car weekly as she was told before my sea time :/
    I charged the accu for 10 hours with current approx. 2 A and the car is running fine, but next week I intend to buy the new 12v battery . It was too long fully discharged in cold conditions :( Anyhow it's 3 years old now and not a big headache.
    BobStein likes this.
  9. tomlondon
    London
    I do actually have a camera/nav - how do you enter the service mode where you can see those screens?
  10. Les_PL
    317
    249
    Gdynia, PL
    1. Press "Power" button without pressing the brake pedal;
    2. Press and hold "Info/Tel" button (see picture, possible you have different version of Nav unit);
    3. Three times switch headlights on/off holding the "info/Tel" button;
    4. Release the above button and voila...
    5. ...the menu appears on the screen.
    Be careful to fiddle with the settings about you are unsure!
    Alfred Focke likes this.
  11. tomlondon
    London
    Thanks, I will give this a go and report the results
  12. tomlondon
    London
    OK, I followed the procedure described above and I got the following results (car completed 12 miles journey and was left alone for 20 minutes in about 0C/32F weather):
    • vehicle switched off and headlights off - 11.8V
    • vehicle switched off and headlights on - 11.3V
    • vehicle on with headlights on - 14.4V
    Doesn't look very well, does it? From what I understand, a good battery should have about 12.6V with the car off and headlights off, shouldn't it?
  13. Les_PL
    317
    249
    Gdynia, PL
    Yeahh... better than mine anyway :) As for now I enjoy the ride having motorcycle battery + jump cables available... After Easter holidays I'll buy new 12V batt.
  14. tomlondon
    London
    I just emailed the dealer, I only picked up the car 2 weeks ago - they way I see it, they owe me a brand new battery ;)
  15. Les_PL
    317
    249
    Gdynia, PL
    Definitely. Now time for some nap, can't wait till morning when I press the "Start" button again - like it soo much :whistle:
    Cheers!
    tomlondon likes this.
  16. Mendel Leisk
    41,824
    Our's had been on the lot a long time, and the battery was deader-than-a-door-nail. Was more cut-and-dry: they acknowledge there was no hope, replaced it as part of Pre-Delivery Inspection. Sitting for months can kill the 12 volt.
  17. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    As far as I know, a Midtronics tester is the only proper and industry-approved method of testing 12v batteries. I do not see how the methods mentioned previously are accurate.
  18. B-52
    B-52 New Member
    Jersey Shore
    In our shop (not a auto shop) the Techs use a 12 volt "Load Tester" on a battery ...It's not a complicated piece of equipment, and I don't see why every auto shop uses one for diagnostics.....
    You simply connect it to a fully charged battery with large clamps similar to jumper cables, push a button for 5 seconds...
    it will draw an instant load on the battery and tell you if the batter is healthy or not....will show a bad cell.....
  19. Les_PL
    317
    249
    Gdynia, PL
    Never heard - you sell them? ;)
    Mentioned previously method is a built-in facility in Toyota Prius for diagnostic purposes.
  20. TwoUnderPar
    TwoUnderPar Member
    78
    72
    I picked up my Prius yesterday (2010, with 27,500 miles). The dealership had installed a new 12V when it first came to them for re-sale. Although not specifically stated, it appeared that this dealership tests all/most of the 12V batteries when they get used cars in and they automatically replace them if anything is "questionable".
