Need tire advice (poll)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by pdq, Mar 25, 2013.
What should I do?
Poll closed Apr 1, 2013.
  1. 1) get extra (standard) rims for winter tires, and summer tires for current rims
    55.6%
  2. 2) get winter and summer tires, and switch (on current rims)
    11.1%
  3. 3) just get all-season set
    33.3%
Multiple votes are allowed.
  1. pdq
    pdq New Member
    I have a 2009 Touring Prius and at ~45k miles, the tires it came with are about done. I live up north where we have weather extremes- cold and snow/ice in winter, 90+ degree days in summer. So I'm thinking I should get two sets of tires- maybe LRR/hi milage for summer, and then winter tires (I've been slipping and sliding too much for my comfort)
    The Touring Prius takes 195/55/16, which it seems is kind of an odd size - for instance, I can get Michelin x-ice Xi2 at clearance (plus maybe rebate) at TireRack right now, but only if I had standard Prius rims. So:
    Should I/could I:
    1) get a set of (cheaper, hopefully) standard Prius rims and put Xi2's on them, and then a summer tire set for my current Touring rims? or
    2) just stick with my current rims and pay to switch the tires twice a year (winter/summer) for the life of the car? or
    3) just get one all-season set?
    I'm not Mario Andretti- just want better traction in winter, and what's maybe most cost-effective.
    Recommendations?
  2. Britprius
    Britprius Senior Member
    5,194
    1,918
    Herefordshire England
    Take a look at what is available and prices in the 205/55/16 size. This is a much more popular size and there is a greater choice of tyres at surprisingly cheaper prices. This size is fine for the Prius with no clearance problems. In the UK and EU all gen2 Prius come with 16 inch wheels.
    This applies to both summer and winter tyres.
    John (Britprius)
  3. cyberpriusII
    1,151
    1,700
    Mars Hotel
    GenII traction is abysmal -- or should I say the fact that loss of traction causes the car to shut down is horrifying -- so my vote would be to get dedicated winter tires and run them from November to April. Run all seasons for the rest of the year.
    Since I don't agree with summer tires, I abstain from the voting.
  4. Mendel Leisk
    40,575
    Can you be a bit more specific than "up north"? Exact street address not needed, LOL, but what region?
    FWIW, our Canadian 3rd Gen Touring came stock with 17" aluminum rims, but for snows we're using steel Corolla rims with Michelin X-Ice in 15".
  5. pdq
    pdq New Member
    "Up north" = Minnesota.
    Britprius, are you saying I can just mount 205/55/16's on the existing rims? Or that I should buy rims to fit that size "tyre" - (you Brits!)
  6. Britprius
    5,194
    1,918
    The 205/55/16's (tyres) will go strait on your existing rims. The extra width improves traction and makes the car much more stable at speed. I run this size as do many people over here. Strange as it may seem the rolling resistance of this size is lower than the 195's so you get better fuel economy.
    If you fit the 205's you will not go back to 195's.
    John (Britprius)
  7. pdq
    pdq New Member
    Thanks much, John - I'll check it out!
  8. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Extra width with snow tires gives less traction. Narrow tires give better traction on ice and snow.;) H
    northwichita likes this.
  9. Britprius
    5,194
    1,918
    Sorry Harold I disagree else why would you lower tyre pressures for ice and snow if not to put more tread on the surface. For water on the road I would agree as this helps reduce aquaplaning.
    John (Britprius)
  10. HaroldW
    716
    95
    Hi john. More weight per square. Inch. Skinny tires are best for snow and ice. Goggle it. Winter rally cars do not use fat tires. You may be corrrect John?. H:)
    cyberpriusII likes this.
  11. cyberpriusII
    1,151
    1,700
    Mars Hotel
    Trust the Canuks....they know of what they speak when it comes to ice and snow....and trust an Oregonian when it comes to rain, wind, fog....
    I read mucha paginas of info when I was trying to figure out my best bet for ice/snow work.....Harold's observation is dead-on. I finally gave up the hassle though and have just gone to tire chains. When you know how to put them on, it really is not that big of a deal (and I only need them a dozen or so times a winter...).
  12. pdq
    pdq New Member
    Can't use tire chains here - probably because we'd be using them all winter, and tear up the roads faster than the winter weather does.
    Actually, a google search tells me that while studs are illegal, I can apparently use tire chains "when road conditions require them". I did not know that - I've never seen anyone using them, but I might check them out.
    I'm now thinking about 205/55/16 Michelin Primacy MXV4's, based on Consumer's Reports and F8L/TireRack's reviews. The former rates it tops in "performance all season" and calls its snow traction "very good", ice braking "good" and it's rolling resistance "excellent". Plus Michelin is doing it's $70 rebate; it looks like Sears will put these on for around $550 total after rebate. Inferior to dedicated winter tires I'm sure, but certainly better than the near-baldies I'm used to, and less hassle and expense than buying another set of rims or paying to remount 2x/yr.
  13. pdq
    pdq New Member
    PS- Do you know if they will require me to use V-rated tires? I'm not a speedster, and I never come anywhere near to the 130 mph that H-rated tires are supposed to be good for, but I seem to remember it being illegal or something to put on tires rated lower than the original equipment (not sure what I have- I'll check the sidewalls).
  14. Britprius
    5,194
    1,918
    Look in the handbook it tells you what rating tyres you should fit, but higher rated tyres are not any more expensive.
    John (Britprius)
  15. cyberpriusII
    1,151
    1,700
    Mars Hotel
    First, in Minnesota, you might need chains often enough that you DON'T want to hassle them.
    Secondly, the higher the speed rating within a particular line of tires the more they will cost -- $$$$ -- sorry John, that's the case here in the U.S. Only makes sense, more cost in testing, materials, etc.
    Third, it is NOT illegal to put tires with a lower speed rating than called for on your car in the UNITED STATES.
    It may be different in merry Olde England, Austria, Spain, or Nigeria...:) Maybe even Canada, they do crazy things in the land of Canada.
    The problem with buying lower rated tires is two-fold -- the tire dealers make more money on V-rated tires than T-rated tires and thus want to sell more V-rated. Also, there is the whole liability issue. If your car calls for V-rated, they put on T-rated and there is some sort of failure they might face some sort of liability.
    I dealt with this whole issue when I had my Mustang as a teen. I worked hard to earn the cash, bought the car and when I needed new tires the tire shop tired to stick me with high-performance tires I could not afford. They claimed it was a safety issue.
    I talked to my family's mechanic as well as the Ford dealer (O.K., my father did) and they all established that it was perfectly safe to put a lower rated tire on the Mustang. Just had to find a tire shop that would do it. We did. Drove that car with the "inferior" rated tires for a couple of years with no troubles.
  16. Britprius
    5,194
    1,918
    No it is not against the law to put lower rated tyres on the car ,but the insurance company will refuse to pay out in case of an accident if they spot usage of the wrong tyres even if the tyres had nothing to do with the accident.
    The speed rating of tyres unless very high performance in Europe does not greatly affect the price. The price is more affected by production costs, mainly the numbers produced. This also affects the price of tyres by size.
    A larger tyre is not always more money than a smaller one of the same make and rating. The 195/55/16 is more expensive by a good margin than a 205/55/16 because many more of the 205's are sold even though they contain more materials and molds ect have to be bigger.
    Again numbers sold also affects the choice of tyres. At the last count there were less than 35 different 195/55/16 tyres available our largest tyre retailer, there were over 120 different tyres in the 205/55/16 size.
    The difficulty arises that in the UK we have a 70 mph max speed limit however if we go over to mainland Europe there are roads with no maximum limit so tyres have to be rated at minimum for the car insurance wise.
    John (Britprius)
  17. HaroldW
    716
    95
    Pdq, have a look at Nokian WR g2 as they are a all weather tire. I run them 100%, and think they are great. They make my Prius a very compfortable auto. A bit pricie but one good tire. Check out thier Web Page. Oh and they are LRR. H
  18. cyberpriusII
    1,151
    1,700
    Mars Hotel
    Not true in the USA.
  19. pdq
    pdq New Member
    So I went to Sears, and they didn't want to do it. Blah blah blah computer will be confused. Should be V, not H, not for speed but because of axle weight, what "with all the batteries and stuff you have in those cars". Suggested that 205/50/16 would be better than 205/55/16, as the diameter would be only 0.3" different rather than 0.5" (like 0.2" is going to make or break?). And they couldn't find the Michelin rebate (maybe not applicable to Sears?)
    Anyway, I'll probably get a few more local opinions. This is a pain.
    I'm not finding them in 195/55/16 either. But thanks for the recommendation.
  20. Britprius
    5,194
    1,918
    The 205's actually improve (make more accurate) both speedo, and the MFD fuel consumption figures. As I've said before many people in the UK, and on PC from the US with touring versions of the Prius use this size.
    As far as confusing computers this is pure BS, as long as you fit a full set of 4.
    John (Britprius)
