Multi Information Display not Working
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Plasmahidef, Nov 10, 2012.
  1. Plasmahidef
    Plasmahidef Junior Member
    Lake County, IL
    My wife on her way home from work called me to say that the MID screen was blank - not working. I asked if she could drive the car, she could, but the energy monitor screen that she has on usually was not coming on. Her concern while driving was that she could not tell how fast she was going. Fortunately, just a week ago I had installed Scangauge II in her car (despite her objection to that ugly thing - her words lol ) and had her convert one of existing gauge to MPH.
    This is a new 2012 Prius IV that is about 2 months old. I'm going to call dealer for service but wanted to know if anybody had experienced it before and somehow she may turned it off accidentally. Although, I'm pretty sure that MID can't be turned off. Any ideas what may have caused it and something I can check before calling the dealer for appointment.
    Thanks.
  2. Adam Leibovitch
    498
    102
    Did she accidentally roll down the dimmer knob while fiddling for the mph/kph button? Not un unpopular thing to happen. Also if the headlights are off and the dimmer switch is rolled to minimum, HID will still display, but with headlights on minimum will not display. One could fiddle with it during the day with headlights off, and not notice until night time. Hopefully thats all it is.
    Clay2013 and JMD like this.
  3. Metalman
    Metalman Member
    107
    17
    Summer, KY; Winter FL
    I had the same problem and it was the panel light dimmer that was set low and I had inadvertently turned on the parking lights.
  4. Plasmahidef
    Lake County, IL
    That was it! Did not even think about it. Learn new stuff everyday. Thank you very much for saving me from feeling like a chump if I had gone to the dealer! ;)
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    If you have to look like an @$$ better here than at the dealer. BTW, everyone here is going to do it sooner or later.
    There's a reason you always ask, "Is it plugged in? Is it turned on?"
  6. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,341
    920
    251
    Surprise, AZ (Phoenix)
    This information is also detailed in your owner's manual. Flipping through that would also save you that "chump" feeling at the dealer.
  7. Plasmahidef
    Lake County, IL
    Actually I did look at the owners manual first before posting here. Unfortunately, I went straight to the MID section but did not see that specific information. After reading your comment, I went back to the Owners manual. You are correct its there, but its under the Instrument Panel Light Control, which is few pages before the MID section. Of course if I had made that connection mentally between dimmer and MID, I would have looked for it, but did not. As some one said, I don't mind being chump here than at the dealer and PC community was quick to help...so in the end its all good!
    HTMLSpinnr likes this.
  8. HTMLSpinnr
    5,341
    920
    251
    Truthfully, this happens so frequently (I wish I had a dollar for every time someone has posted this concern over the last 10+ years of Priuschat, Y! Groups, etc.), it really should be part of the troubleshooting section in the manual. I'll give you props for checking, and point the finger at Toyota's technical writers for not putting a "warning" or "note" section.
  9. amberlea
    amberlea Junior Member
    36
    Tennessee
    What about if only half of the display is working and the other half is not? I had a dead battery and had to jump start this morning. On my way to work, I noticed the part of the display that shows the graph, etc. was not on. The speed section was on. Any thoughts on what the problem could be in this case?
    Thanks!
  10. Plasmahidef
    Lake County, IL
    Sorry amberlea, I do not have an answer for that. Hopefully other experts from PC will chime in. The only thing I would hazard to guess may be its related to your dead battery/ weak battery problem.
  11. blizzardwhat
    blizzardwhat Junior Member
    35
    SoCal
    Wow I had the exact same problem tonight.
    I've only had my prius for a week and thought it malfunction and was asking myself why did I buy this pos. lol
    I came to this forum and problem solved. :)
  12. BinaBomb
    BinaBomb Junior Member
    New Brighton, Minnesota
    I know this an old post, but... Hey amberlea, I just had the same exact scenario happen to me this morning. I was in a rush, so I went to start my car, ran back inside the house and found that the whole display was visible, but dimly lit. This is when I figured that I had a dead battery. I jumped the car, but then when I was backing out of my driveway I noticed that the speedometer portion of the display was working, but the multi information display was dark. Did you ever figure out what was wrong, or did it just fix itself?
    Thanks,
  13. BinaBomb
    I started the car over the noon hour, and now the both sides of the display are working correctly. Perhaps the car needed to "reset" something after the jump. My problem is solved... for now.
  14. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    Is the battery original? If so, replacement is a very real probability.
  15. BinaBomb
    I am the second owner, but the battery appears to be original. I did notice this morning that my drivers door was slightly ajar, most likely enough to keep the interior light on all night. With that said, it is a 2010 with 25k miles, I would hope that a battery would not be needed at this time. Since I did drain the battery down I was considering removing and charging, but I am not sure if that would be worth the effort.
  16. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    You should be able to charge the battery under the hood. Use a charger that uses no more than 4 amps if possible.
  17. BinaBomb
    Would there be any issue with charging directly on the 12v batter posts rather than using the charging location under the hood? The reason I ask is because my engine compartment is current inaccessible due to someone pulling out in front of me.:mad: I could possibly open the hood, but there is no guarantee that I would be able to get it latched again. [​IMG]
  18. jdk2
    jdk2 Active Member
    751
    220
    Raleigh, NC
    2013 Prius Plug-in
    No problem charging from either location. Usually it's just easier to charge from under the hood. I see what you're saying though.
  19. SharonK
    SharonK New Member
    Katy, TX
    Thank you for posting this. You saved my life tonight.
  20. Dark_matter_doesn't
    Dark_matter_doesn't Prius Tinkerer
    691
    151
    Seattle, WA
    I bought a Battery Minder (about $40) and hooked its cable up to the battery terminals and have it sticking out of the passenger side of the cargo deck cover.
