Disgruntled Real Electric Car Owner
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by flim, Mar 30, 2013.
  1. flim
    flim Active Member
    260
    183
    Huntington Beach, California
    2023 Prius Prime
    XSE Premium
    I was the only car charging (2 EV stations) at Bella Terra in Huntington Beach and someone left this note on my PIP a few weeks ago.
    I normally see PIPS, Leafs and Volts vying for those two EV stations and recently a Tesla S was charging next to me.
    It must be a Leaf owner who left this note.
  2. lopezjm2001
    lopezjm2001 Senior Member
    1,146
    407
    Sydney Australia
    Sounds like he had a case of the PIPs.
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    How long did you occupy the spot?
  4. flim
    flim Active Member
    260
    183
    2023 Prius Prime
    XSE Premium
    About an hour and no one was even using the other charging station.
    The 5 miles reference probably came from the total charge time of about 1 hr or approximately 5 EV miles added when it finished charging
  5. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :confused:Someone is holier than thou? There isn't a EV charging protocol or pecking order in real life. This individual would have been pissed regardless of what was being charged. Hold your head high, fellow PIP owner.
    Andyprius1 likes this.
  6. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    Part of the issue is that that pure BEV owners might actually need to charge in order to get home or to their destination. PHEVs, esp. w/short EV range don't.
    There's been a lot of discussion of EV charging etiquette at MyNissanLeaf.com but much of the protocol far predates the Leaf.
    JimPHL likes this.
  7. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :DI have a one word solution. Hybrid.
  8. cwerdna
    12,544
    2,124
    SF Bay Area, CA
    There are folks who would like to eliminate their burning of oil (and refined products from it) in their vehicles. Pure BEVs do that. Hybrids don't.
    There are numerous reasons (e.g. not sending $ to Big Oil, foreign countries and dictators, using only domestic energy sources, using renewable energy, environmental, etc.) One person at MNL puts in his sig "No American soldier has ever served on foreign soil to bring electricity to this country".
    You can't run your hybrid from solar panels. You also can't run your hybrid from hydroelectric power or wind power.
    My Nissan Leaf Forum • View topic - Most miles on a Leaf passed 70K miles on his Leaf in ~2 years, all w/o burning any gasoline.
    Perhaps articles like Electric Charging Station Etiquette for Plug-In Cars should give you some insight. Some EV drivers use the protocol/etiquette cards or something similar.
    (FWIW, I do plan to lease a Leaf. Long story why I don't have one yet.)
    JimPHL, Zythryn and F8L like this.
  9. El Dobro
    El Dobro A Member
    7,093
    3,271
    Now, that's what I would call pipping a person off.
    longshot and DianneWhitmire like this.
  10. bisco
    52,371
    i haven't read the protocol, does it say pips shouldn't use public chargers?
  11. evfinder
    evfinder Member
    293
    72
    Some EV drivers think that charging stations should be for their exclusive use. Reality is that PIP owners have just as much right to use public charging as anyone else. If they are worried about lack of chargers they should either live within their range or use their energy to campaign for more infrastructure.
    usbseawolf2000 and Tracksyde like this.
  12. bisco
    52,371
  13. ItsNotAboutTheMoney
    ItsNotAboutTheMoney EditProfOptInfoCustomUser Title
    2,287
    460
    Maine
    This is why public chargers shouldn't be free. Free is always cheaper than plugging in at home. With free (or subscription-based) public charging the only result to expect is inefficient charging (both economically and in terms of energy). Charging is relatively slow and low cost which means that it should be easy to have a nationwide charging network with ID cards since even if everybody in the country drove an electric car the number of transactions per day would be low and fraud would be low. The only thing getting in the way is people insisting that charging networks have to make a profit.
    Once you have public charging at electricity+small fee then opportunity charging will be reduced and you can be more confident that people charging will benefit in a way that either reduces gasoline consumption or provides enabling range.
    Then it's a matter of altruism. If I drove a PiP I would avoid taking a charger in a busy spot since my charging would have the least benefit. I'd do it even at free charging spots too, but I wouldn't feel as confident in my decision.
  14. -1-
    -1- Don
    1,254
    439
    Chester, Virginia
    2024 Prius Prime
    :)I'm not going to get into the politics or political correctness of using public charging stations. They're not a issue with me. I have a Level 2 charger at home and at work. Can't imagine I'd be any where else that I'd require a charge or have the time. I like the idea of the Prius Plug-In, as the best of both worlds. But, extended EV range in the future will be welcomed. I wouldn't consider a all electric vehicle at this time as too confining. I have very little experience running out of gas. I can only imagine, running out of battery power would be worse.
  15. hb06
    hb06 Member
    550
    Huntington Beach, CA
    Plugin Hybrids PHVs have their own legitimate issue for charging which is to maximize MPG and therefore minimize fuel and emissions. In that regard, all alternative vehicles have the same mission and should accommodate each other. It also seems like in the majority of cases at a charging station at local markets and stores, the EVs are themselves just topping off as they most likely do not even need the charge with their extended range.
    iplug and Tracksyde like this.
  16. Cacti
    Cacti Poleikleng
    193
    Massachusetts
    Do you know if the charging station was a Coulomb model CT2101? This station has dual level 1 and level 2- Power: 120 VAC 16 A and 208/240 VAC 30 A. The level 1 can be accessed by opening the door on the front which conceals the level 1 outlet. If you are not aware of this feature you may miss an oppourtunity to charge thinking the charging station is occupied with the 208/240 VAC and not available to others. You do need your cord/brick to plug into the level 1.
    Cacti
  17. Totmacher
    Totmacher Honey Badger don't give a carp
    301
    110
    Mission Viejo, CA
    and a parking space adjacent to the chargeing space.
    Here is my etique... I see a vacent spot, I pull in and plug in. End of discussion.
    DianneWhitmire likes this.
  18. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    You should read it Bisco, it is quite interesting and well written.
  19. Andyprius1
    2,327
    859
    Cool CA
    . The etiquette says, that is appropriate .
  20. Andyprius1
    2,327
    859
    Cool CA
    According to some of the very latest technologies, a range of 1000 miles is now feasIble.
