NEED Easy Instructions on changing inverter coolant pump fluid
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ski.dive, Mar 31, 2013.
  1. ski.dive
    ski.dive Active Member
    964
    242
    Hutchinson Island,FL. Mt. Snow,VT
    I'm looking for easy step by step Instructions on changing the inverter coolant pump fluid.
    Is it easy to change?
    At how many miles should I change it?
  2. Paradox
    29,110
    8,592
    201
    2014 Prius v wagon
    Moved to the proper forum
  3. magnumrtawd
    magnumrtawd Member
    306
    72
    Toledo,Ohio
    AND WHAT FORUM WOULD THAT BE???
  4. jdenenberg
    jdenenberg EE Professor
    3,938
    1,936
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Use the search functions, but "easy" may not be the correct description
    Easier than doing the ICE coolant, but both normally need you to use computer commands to open and close valves to properly bleed air from each system
    Both current loops should be refreshed at 100k miles and then every 50k miles thereafter. Use only Toyota SSL (pink, pre-mixed) coolant.
    JeffD
