Question about filling up
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by THF, Apr 1, 2013.
  1. THF
    THF Junior Member
    71
    MO Ozarks
    I have a question about how far you can go before needing to actually refuel. In our truck, we only have to fill up after about 350 miles. Of course, it's a 26 gallon fuel tank. So, if the Prius is (roughly) 10-11 gallons, then at our 46.5 MPG, we should be able to get 465 - 512 miles before refueling. Yet the most I've been able to go in the car is 300 miles and the most I've ever put in is just about 7 gallons. While this is more comfortable than filling up a 26 gallon tank weekly, it is still somewhat annoying to be filling up every 6 days. Any thoughts?
  2. ursle
    ursle Gas miser
    1,049
    192
    NH
    Your gen2 prius has a metal tank with a plastic bladder, when it get's below 72 degrees the bladder starts to contract, when it sit's at 40ish degrees, (winter for you) it contracts sufficiently to decrease the amount of gas the tank will hold, so, as it's getting above 72 degrees these days, the tank will hold more, the overall mileage per tank will increase.
  3. maestro8
    maestro8 Nouveau Member
    471
    109
    nor cal
    The consensus here is to refill when you see one pip left on the fuel meter. At this point, the measurement is not very accurate, could be 1 gallon, could be 3, who knows... go any further and you're tempting the fates.
    If you want to live dangerously, try climbing mountains. Trifling about your fuel gauge is pointless and boring. There are much greater problems one will face in life than having to visit the gas station.
  4. fuzzy1
    10,474
    About a hundred threads worth on this topic.
    Nearly all cars have a significant portion of the fuel tank held as safety margin, beyond the low fuel warning. 100-ish miles (or 2-ish gallons on a Gen3 Prius) is typical, though this varies considerably.
    But as previously noted, your Gen2 Prius fuel tank contains a flexible bladder, which is infamous for adding considerable inconsistency and uncertainty compared to the already uncertain fuel level of other cars.
    You didn't say how far down the fuel gauge you have gone before refilling. While some Gen2 drivers have repeatedly gone far beyond the Distance To Empty = 0, others have run dry with one or two solid bars remaining, well before any low fuel warning. Driver beware.
  5. THF
    THF Junior Member
    71
    MO Ozarks
    I fill whenever it lowers to one bar, which is around 275 miles each time. I merely wanted to know if this is typical.
  6. wb9tyj
    wb9tyj 2017 Prius Prime Advanced
    389
    95
    Indiana and Nevada
    275 seems a bit low to me...i;m usually at 250 with 5 bars left...but when i fill...i fill slowly and burp it as i go...so it doesnt spill out...once the pump clicks off...i go 1 more gallon+/- and thats where i stop...so with 2-3 bars left i'm approaching 300 miles more-less...most of the time...winter less...summer lots more miles...
  7. steve_b
    steve_b New Member
    South Central PA.
    Thats exactly how our 2005 is behaving in the cold weather. I usually fill it at about 1 pip left which is around 270 miles. I fill it slow and stop when it clicks. Never took more than 7.2 gallons so far, even when I took it down to the flashing pip. Haven't owned the car in warm weather yet, but they say you can put more full in and get better fuel mileage in warm weather.
  8. THF
    THF Junior Member
    71
    MO Ozarks
    I see, good to know. It has been fairly cold here. I find the concept of the prius "bladder" strange; makes it seem more like a living thing than just a computer on wheels. Thanks everyone for your responses!
