My drivers door arm rest is cracked and broken.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ewxlt66, Apr 1, 2013.
  1. ewxlt66
    ewxlt66 Active Member
    535
    186
    Dana Point, CA
    So random. Right where my elbow goes, the plastic has more or less shattered a part, held together by the cloth.
    Also, where it would hand on the door it cannot any more, so any weight on it and it simply moves down.
    Anybody seen or heard of this?
  2. rocketrob
    rocketrob Member
    104
    Los Angeles
    Same here. The plastic under the fabric on the elbow rest part cracked one day while I was adjusting my seat position. Only my armrest is still firmly affixed to the door so it still carries weight.
  3. ewxlt66
    535
    186
    Dana Point, CA
    I'm afraid to hear what the dealer would say cost wise. *shudders
  4. 2k1Toaster
    6,035
    3,856
    Rocky Mountains
    No problems with my armrest in my 2006 with 108K miles on it. The cloth is darker there from the oils in my skin over the years (gross but true) but it otherwise looks and works perfectly.
  5. bobodaclown
    bobodaclown Member
    216
    72
    Wife did it to her side. Any suggestions? Repair part?
    Bob
  6. ewxlt66
    535
    186
    Dana Point, CA
    No clue! That's why I posted this up here. :)
  7. TampaPrius.com
    TampaPrius.com Active Member
    461
    300
    Tampa, Florida
    I just repaired one today. I see it quite often on older Prii. The only option the Toyota dealer offers is complete door panel replacement. $600-700.
    Here are some steps to repair it. I have attached some pictures below in no particular order.
    1. Remove door panel (there are 2 screws to remove, one is hiding behind the plastic cap behind door lever) then insert a trim tool or butter knife and pry the trim tabs, once they are all loose lift up on the panel.
    2. Pry up the panel with the switches on it. undo the connectors, there are three, one is the puddle light and the other two go to the window and lock switches.
    3. Flip the panel over and put it on a desk or workbench, now you can see why it broke. There are some perforations in the plastic support and it doesn't take much to break them.
    4. To remove the armrest you have to melt or cut off the tabs that hold it on. There are 6 of them. I used a razor blade and cut them off.
    5. Once the armrest is removed, make a template with paper of the shape you need and then find a piece of thin sturdy plastic. I used an old DVD movie case. Use your template to cut the plastic in the same shape.
    6. Now align all the broken pieces back where they go and lay a bead of super glue gel or a strong plastic glue( I used super glue gel) along the broken perforations and all over the surface and affix your cut re-inforcement to it.
    7. Let dry
    8. Re-assemble. Use small screws with washers to reattach.
    snead_c, Dino33ca and ewxlt66 like this.
  8. bobodaclown
    bobodaclown Member
    216
    72
    Great info! Thanks.
  9. ewxlt66
    535
    186
    Dana Point, CA
    Wow! Thank you!
  10. Pandalover
    Pandalover Junior Member
    82
    UK
    Thank you for this. I had the exact same problem. It's a bit of a design flaw on Toyota's part.
    I found detailed instructions for removing the door panel here Armrest covering | PriusChat
    I didn't bother popping the arm rest off but I did use your DVD case trick and glued in place. Fingers crossed it holds ok :)
    snead_c and TampaPrius.com like this.
  11. TampaPrius.com
    461
    300
    Tampa, Florida
    I guess there really is no reason t remove it.
  12. nitteo
    nitteo Junior Member
    29
    Weston FL
    Thanks for this. My driver broke also. I am gonna look for something sturdier than a dvd case.
    I will have to remove it, since I am going to repair the covering as well.
    I will install vinyll on them all. the armrests are cloth and filthy from the previous owner.
