Best delivery vehicle for Pizza Man?
Discussion in 'Gen 2 Prius Main Forum' started by Dino33ca, Apr 3, 2013.
  1. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Hi guys. First post here. Was hoping to get your opinions. I'm a full time pizza deliver guy. My best delivery vehicle to date was an '03 Echo as far as reliability and overall cost. However someone rear ended my old pal and now I'm trying to decide if I should buy another Echo or go with a Prius. From what I can tell I'd be saving about ten miles per gallon on a Prius, but the initial cost is going to be at least a couple of thousand dollars more than the Echo. My main concern is maintenance costs. I've heard both cars are reliable, but I've heard about computer problems and potential battery problems on the Prius. So here's the question what do you guys think the most economical vehicle would be over a period of at least a few years a 2005 Echo with 125k or an '04 Prius with the same 125k??? My brain tells me the Echo, but the heart says the Prius.
    Here is a Prius I might be looking at tomorrow, owner says it's in pristine condition with new windshield and tires. It's an '04 with about 139k on it. One note it has a declaration of damage over $2k from a dear hit, but was professionally fixed. They will take $7500 Original Battery.....
    Toyota Prius, hybrid
  2. The Electric Me
    The Electric Me Go Speed Go!
    9,083
    5,798
    Undisclosed Location
    Ugh...just like yourself, my mind tells me to recommend the Echo. But my heart wants to tell you the Prius is okay. Because it seems the Prius is really what you want.
    But I really just can't.
    Over $2000 dollar damage done by a deer hit? Is it a clean title?
    I've looked at numerous vehicles on Craigslist and anyone and everyone selling a vehicle with a branded or salvaged title or with undeniable damage in it's history ALWAYS say "The Damage Was Professionally Fixed or Repaired". I have yet to see somebody say " The damage was horrific and the repair work was sloppily completed by a one armed drunken Idiot".
    So right off the bat, that makes me very nervous.
    Plus are we dealing in the minimum with a Car Fax here? Single previous owners? Them giving the definition of "Pristine Condition" is really worthless once you've given them the money and they have handed you the title. Infact I'd say any vehicle 9 years old and with 139K on it, can't by my standards be in "Pristine Condition". No knock on the vehicle, it's just you don't get to 9 years old with a 139K on the odometer and be in Pristine Condition. You can be in very, very good condition for that age, but you aren't going to be in Pristine Condition. The pictures in the ad, aren't representative of a vehicle that is in Pristine Condition IMO.
    Also you say new windshield and new tires. If these owners are the only owners, or have owned the vehicle very long at all then I would say after 9 years there should be a lot more maintenance records available. Do they have them? Can they show you all they have done in almost decade? Because it should be more than just tires and a windshield. If it was "Professionally Repaired" after $2000 plus worth of damage? They should have the records for those repairs, where and who did them, and exactly what was done.
    If you're still not frightened off? I'd say if it was me? I'd want to have the vehicle inspected before I purchased. Can you afford this? Can you afford to NOT be able to afford this? Because IMO as a older Hybrid that has been involved in at least $2000 dollars of damage, you need it checked out as thoroughly as possible.
    If you can get through all these hoops with it? I'd say...maybe. That's as much as my "heart" can give you on this. Because my mind says you are probably safer going with an unwrecked and cheaper Toyota Echo.
    kenoarto likes this.
  3. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    Thanks Electric. I feel the same way. The fellow says all the records for the car are at the local dealership. We have pretty tough standards on autobody repairs here. Apparently they are higher than factory specs. It'd be easy for me to inspect the vehicle myself but it's about an hour and a half drive away from here. Not sure what to think, getting cold feet a little. I was very excited several days ago when I drove a Prius through an auction lot. I bid on the same vehicle when it went through the auction. I won high bid at $5300 for an '04 with about 70k miles on it but it didn't meat the reserve at $6k. I didn't match the reserve because it had the red triangle light on and I took the vin over to the local Toyota dealership and they told me the knew the vehicle and that it needed a battery pack. It was a very cool experience driving it through the lot, the hybrid bug bit me somewhat...
  4. Patrick Wong
    18,200
    6,479
    If your finances will not allow you to accept the risk of four-digit repair bills then you should listen to your brain. The Prius is highly reliable. However 125K-139K miles is near "end of life". It wouldn't be surprising if the traction battery, transaxle or inverter on such a Prius were to fail tomorrow.
    Further, you are taking a big risk by buying a vehicle known to have been in a significant front-end collision. What corners were cut in repairing the car for resale?
  5. Kermitt
    Kermitt Junior Member
    Austin, TX
    Someone who uses those seat covers cannot be trusted!!! :p
    The Electric Me likes this.
  6. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    I was a delivery person (chinese food) for 5 years. I delivered 5 nights a week for 5 hours minimum. On weekends sometimes I would work the full 9am to 11pm. For the last couple years I used the Prius and it was the best thing since sliced bread or in your case pre-cut pizza.
    One of my favourites was the 3 door SKS. No key required in the vehicle. I could run up to a house, hop out deliver the food, hop back in and be off without ever looking for a key or turning the vehicle off. With the vehicle still in READY, and key in my pocket, a thief would only get as far as the next power off and then it would be stuck. If you do turn it off every time, jabbing a button on your way out and while about to sit down is much faster than a key turning. This saved me a bunch of time. I actually used my remote start on my Honda Civic before to do the same thing. I would pull up to the house, then remote start the car (with the car still on so it would just keep it on), take out the key, deliver, put the key in and drive away again. But putting the key back in was a PITA in the dark or when you have 10 orders in the car, you only have 35 minutes to deliver all of them, and you know there are another 10 waiting for you the second you get back to the restaurant.
    The big benefit related to above is fuel savings. On paper for normal people, you will probably save 10mpg. However, for delivery people, you can almost double that. Keep in mind that when you are waiting for some annoying customer to waddle to the door and your engine is idling, you are burning fuel and getting 0 miles to the gallon. With the Prius, the engine shuts off, and you are using a couple hundred watts of battery power that automatically recharges. So all that idle time is reduced to essentially off time. But you don't have to worry about your starter, your starting battery, or using extra fuel starting it up, idling fuel, any of that. It is just taken care of.
    In the Prius I could also fit 6 delivery bags and 4 2-litre pop bottles on the ground in the passenger side footwell all accessible while driving to bend over and read the hand written addresses. In the GenIII (2010 to 2013) that would be a deal breaker because the bridge is so friggin annoying and in the way. GenII (2004-2009) are perfect for delivery. The seats are bucket seats like most modern cars so I generally had to put a wedge there to make it flat for the extra 4-6 bags to sit flush. Otherwise in the back seat they would go. For pizza, if you use those big bags, you shouldn't have a problem and the hatch is so roomy. You can't do that with quarts of soup though.
    Another benefit which was specific to my delivery area was the silence. I delivered to an area where probably 80% of the orders were on a military base. So every time you went out to delivery, you had to wait in a checkpoint inspection line get out open everything up and so on. Gas saved idling there too. But then once on base, the parking lot for a set of barracks would be a football field sized piece of land away in some cases. That extra minute there and back is unacceptable when delivering. So people would jump the curb, drive on the grass and rocks to park right next to the building to get a fast delivery. Pretty often the Military Police (MP's) would catch you and you would get a $50 ticket wiping half your nights tips away like that. With the Prius however, I could turn the lights off, turn the MFD off, hit my EV button and then hop the curb and sneak past the on-duty soldier without making a sound. Delivery my bounty, then race the hell out of there.
    The Prius or a similar hybrid is the best for delivering from my experience. Add to that long oil change intervals, no stress on the 12v starting battery like a normal delivery car, great fuel economy, long lasting 100K-200K or more brake pads, the good design, the silence, etc and it is a no brainer.
    The traction battery LOVES being used as a delivery vehicle. If the battery could, it would be tendered and pampered 24/7. In normal Prii, it is only answered for 30 minutes here and there for work commutes and a little bit for errands. In a delivery vehicle it gets 5+ hours of nonstop pampering from the Toyota battery controllers keeping it in a perfect state of bliss. It doesn't get hot, it doesn't get discharged, it doesn't get overcharged, it can bleed or charge itself whenever it wants, it is a happy camper. So I would not worry about that.
    Having said that, any car with over 100K miles is a suspicious car. And 139K of evil usage, might never be recoverable on the systems. Your 100K+ car has at least 1 reported accident in the front. Lots of very important things in that area. The Prius works perfectly as built in Japan. Get Bubba to hobble some stuff together, and it is not the same. I would fork over some more money for a non-salvage vehicle with lower miles. This car will probably outlast your delivering days.
    Dino33ca, JMD and THF like this.
  7. THF
    THF Junior Member
    71
    MO Ozarks
    Interesting. I have never heard such a low estimate on mileage life. I have a prius with 166k and drive 20k+ yearly. How long will this thing last?!
    It does not sound like you buy used cars too often. Deer damages are frequent around here, and most people are experienced in knowing what to look for. However, hybrids are so much different; it's hard to know what could go wrong with a frontal impact. If it was fixed, I would imagine there would be nothing wrong with it.
    Also, I would like to point out that we also have a Tundra w/ 288k+ miles on it - and it still runs perfectly. Original trannie and engine. Nothing except routine maintenance.
    To the OP: A Prius would be very nice for your delivery job. BUT, is the extra cost actually worth it? You'd need to sit down with pen and paper and punch some numbers out; short term, long term, etc. That's the only way you'll know.
  8. The Electric Me
    9,083
    5,798
    I've purchased plenty of used vehicles in my life and IMO it doesn't matter how "frequent" Deer Damages might be in any given area, an impact is an impact and 2000+ dollars of damage repaired is 2000+ dollars worth of damage repaired.
    Yes, anything damaged can be repaired and repaired correctly but if you are on a budget? And pushing the outer limits of that budget the buyer can't afford to leave it to "I would IMAGINE there would be nothing wrong with it.". The OP has to KNOW there is nothing wrong with it. Which is why I suggested he get it professionally inspected. If he has the skills and confidence to do it himself? Fine, more power to him.
    If you are leaving your decision in this matter up to "imagining" there would be nothing wrong with it, then I would say you are the one that hasn't bought a lot of used cars, because IMO that's a dangerous approach. Like I said, everyone who is selling a car with undeniable damage in its past says "It was fixed correctly and professionally" but here's a little hint, that doesn't always mean it was fixed correctly and professionally.
    Kermitt likes this.
  9. jdenenberg
    jdenenberg EE Professor
    3,863
    1,865
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When I was in college (in the late 60's - 1960s, not 1860s), I delivered pizza in my Triumph TR4. It was economical and quick in turns, so I was the fastest delivery guy for the restaurant.
    JeffD
    JMD likes this.
  10. Kermitt
    Austin, TX
  11. JMD
    JMD 2012 Prius 4 Solar Roof
    3,779
    1,282
    So what are you delivering Papa Johns or Pizza Hut?
  12. Dino33ca
    Dino33ca Member
    168
    34
    British Columbia
    JMD: "So what are you delivering Papa Johns or Pizza Hut?"
    Panago Pizza. A fairly popular franchise here in Western Canada.
    Thanks for all the responses everyone. It's much appreciated. I had a funny morning while contemplating my upcoming purchase. This morning I had made up my mind to go with the Echo. Never took the hour and a half drive to see the above linked Prius I went out for coffee to our local Tim Hortons and was going to come back and phone a fellow selling an '03 Echo that is in excellent shape with a/c and remote start, etc. On my way home I stopped by the auction grounds that are on my route. I was amazed to find another '04 Prius sitting on the lot. It looked exactly like the other Prius I bid on a couple of weeks earlier, had to make sure that it wasn't the same one, and it's not. They must be from a corporate fleet because they were nearly identical? Anyways, I took it for a drive around the lot, no warning lights, seems to work fine. I took this as a sign that I should still consider a Prius! The auction is coming up this Saturday. I'm hoping to be able to get it for $6K. If I can and it meets the reserve I'll be a prius owner! Its a greyish green color, has driving lights. I believe it may be a base model? It has 135K kms, or about 84K miles if my memory is correct. It just came into the auction lot today. I'm fairly confident the Prius would make a good delivery vehicle, in part because of reading your posts here on this forum. Thanks again....
    This is a link to their inventory but they have not posted it yet on their website...
    Kelowna Auction World - Cars
    Here is a link to the '03 Echo that I'm considering....
    FOR SALE 2003 TOYOTA ECHO 4 DR SEDAN - Castanet Classifieds
  13. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    Have two clients that use a prius for deliveries. One gets about 36 mpg in his 06 and the other gets about 38mpg in his 08. If the trips were long enough, I would get a prius fro deliveries. Short commutes from here to there kill your MPG. Stick with an echo.
  14. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Your drivers suck then.
    I got mid to high 40's in my Prius when I delivered. 3mile radius from the restaurant was the furthest we went.
  15. JMD
    3,779
    1,282
    Hope it works out for you!
    Cheesy Bread looks good
  16. ovni
    ovni Member
    243
    91
    Sugar Land, TX
    3 mile radius is pretty big. These guys deliver within a one mile radius in downtown SF. Meals on wheels...
  17. THF
    THF Junior Member
    71
    MO Ozarks
    You are probably not used to running into deer, then. People around here run into deer all the time. If it were a really big deal (which is sometimes is, don't get me wrong) then it would be hard to live down here. Typically it's just the bumper, lights, maybe the hood and windshield if it gets far enough, or the radiator if it's big enough, stuff like that. Rarely does hitting a deer do something like throw the alignment out, or wreck it. $2k is easy to wrack up for some dents and a windshield.
    [If you are leaving your decision in this matter up to "imagining" ...]
    Classy...
    Anyways, clearly, from the previous description here, I am not imagining. If the vehicle ran, etc. there is a very good possibility that it was still a fine car. There, rephrased. Forgive me for using the wrong verb.
    To the OP: Congrats; hope you get it! That is very good mileage for an '04.
  18. The Electric Me
    9,083
    5,798
    Okay...you caught me,- I have never hit a deer. And I live in the Pacific Northwest....there ARE a lot of deer. ( I'll keep trying....no, no, that's not right....I didn't mean that...)
    I also agree, body work can add up in cost very quickly. I BARELY had my back bumper hit, and when all was said and done it was about $1000 dollars damage.
    I just would hope the OP makes as informed a decision about the vehicle he is going to eventually buy as possible.
    THF likes this.
  19. quantumphaser
    quantumphaser New Member
    North Carolina
    I deliver for Dominos and they pay me about $400 a month average for mileage, 20 cents per mile. I picked up a fully loaded 2008 Touring model with 115k on the odo for $7900. Clean carfax, the engine compartment spotless, all fliuds clean, very well maintained and drives like a new car. I get no less than 38mpg but usually about 42mpg. The car payment is $190 per month for a 4 year loan and adding full cover coverage is $60 per month as an additional vehicle. I spend about $120 a month for gas for deliveries. So basically the car is paid for just from the mileage reimbursement. I use Mobil 1 0w 30 Advanced Fuel formula synthetic oil in it with the Mobil 1 filter, changed every 5k. The car is excellent as a delivery vehicle and has all the toys which makes it a pleasure to drive. I've gotten very good at feathering the accelerator and keeping it in EV mode in the neighborhoods. I drive very carefully anyways so the car is perfect for this task. I would highly recommend it to anyone who is contemplating this decision. Besides that I am already saving a ton in fuel when I use it for non business. READ "Car that pays for itself!"
    No need to buy a stripped down beat up piece of junk when there are plenty of good ones to be had. Skip the eco versions and go right fornthe touring with leather. ALSO get 15s for the wheels, mine came those. The 16s use more fuel and there is less meat on the tires to protect the rims. I can tell you that I deliver on some awful roads, part of the business. When I see Prius's out there with 400, 500, and even 600k on them used as taxis, I don't worry about longevity.
    Fliuds are the key. Change oil every 5k min and transmission every 40k. Use only OEM fluid, of course.
    Love, Love, Love my Prius.
    Happy Motoring
  20. JMalmsteen
    JMalmsteen I love my Prius!
    275
    262
    Long Island, NY/Lancaster, PA
    I would get a Prius but not the one you mentioned. I've seen plenty of bargains on 2007-2008 models from $2500-5000.
    Our battery went at 469k miles. I'm not saying that's typical, and we have spent hardly anything on repairs. This has been the most reliable car I have ever owned.
    That car you are looking at is worth at most 3k.
