new tires, lower mpg
Discussion in 'Gen 2 Prius Fuel Economy' started by rad911, May 5, 2009.
  1. rad911
    rad911 New Member
    rossmoor california
    hello to all of you experts. i was getting close to 48 or 49mpg with a mix of highway and street driving and feeling pretty good about it. last month i changed my tires to some random costco tires, and now i am at 42 mpg. i recently did a 4 wheel alignment at the stealer for $140 and no change. is this common? is there a tire break in period or did i buy the wrong tires? very sad.
  2. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    Same size tires or did you go for larger tires?
  3. msirach
    msirach Member
    321
    Southern Illinois
    Combo:
    New tires will have a certain run-in period. Michelin Energy that I put on a HCHII had about a 3000 mile before it was back to normal.
    Random tire? It's very possible that you increased rolling resistance exponentially by putting "any" tire on the Pri.
  4. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    when I changed my tires back in November. I went with wider 195/60R15 tires as I wanted to add some handling and stopping power and the tires I wanted also didn't come in the stock size. Anyway it took about 3000 - 5000 miles (hard to determine because of the extra cold winter this year), but my MPG is back to about 58 MPG now that its warmed up a little.
  5. drees
    drees Senior Member
    1,782
    247
    I'm guessing you got the BF Goodrich Traction T/A as they were significantly cheaper than the Michelin's.
    My dad did the same thing for his Prius and he's been complaining about how poor his fuel economy has been. He normally gets close to 50 and now it's low/mid 40s with the new tires.
    They've slowly been getting better with more miles on them and after inflating them to 42f/40r. I'd estimate you'd need to get at least 10k miles on the tires before you start getting close to the same fuel economy as before.
    I really wish they'd hurry up and already make rolling resistance information information available on the sidewalls of all tires like the rest of the tire performance information.
  6. matt b.
    matt b. Member
    251
    60
    L.A.
    you need low rolling resistant tires 27'6 the yokohama manufacturer. your mileage could get worse, take them back and get the s33 yok
  7. Mendel Leisk
    41,281
    If the OP doesn't come back to clarify "random Costco tires" this is going to get old real quick.
  8. Bmr4life
    Bmr4life Member
    131
    56
    Atlanta, GA
    2014 Prius v wagon
    Lol this thread is from 09
    ADR6425LVW ? 2
    wjtracy likes this.
  9. F8L
    19,011
    4,083
    Grass Valley, CA.
    Matt. Please refrain from giving out bad information like this. You're not even in the correct forum. The GenII didn't even come with Yokohama tires! :p
    Damn zombie threads. LOL
  10. uart
    uart Senior Member
    4,220
    1,210
    Australia
    See. Mendel was right!. :ROFLMAO:
    Bmr4life and F8L like this.
  11. Mendel Leisk
    41,281
  12. ataylorracing
    ataylorracing ataylorracing
    171
    29
    Fishers, IN
    We have no experience with replacement tires yet....EXCEPT...our same size studded snow tires at the same air pressures as the original equipment tires killed our 50 mpg all around town to 43. The studded snows are a half pound heavier, but I definitely think the rolling resistance is the biggest problem. Last year there was only maybe one day of driving in glare ice that these tires work best at, 4 times this year. We don't mind having better glare ice traction for a reduction in mpg though. We can drive much better than 4wd big trucks.
  13. FuelMiser
    FuelMiser Senior Member
    1,349
    928
    Monument, CO
    I also put some cheaper "random" tires on a few sets ago, and noticed an immediate drop in mileage. I did the math and determined increased fuel costs way outweighed the savings on the tires. Last two sets have been Continental Pro Contact Eco Plus and am happy again with MPG.
    F8L likes this.
  14. F8L
    19,011
    4,083
    Grass Valley, CA.
    Did this loss account for weather too? I.e. you swapped to the winter tires and noticed the loss immediately? If so please tell us which tires you have for summer and winter. :)
